Hi Guys,
Sorry about this as my first post but I am currently rebuilding my RB25 after it threw #4's rod a couple of months back.
This time everything has been looked at so my question now is what do I need belt wise for the power steering etc to fit an ATI 1000hp rated damper pulley to an RB25 using the stock RB25 crank + JUN oil pump collar?
https://www.sau.com.au/forums/topic/188341-ati-damper-pulleys-for-the-rb25det/
well if the ATI damper is made for the rb25 then the standard belts should work, will be tricky if you are using the rb26 damper though as the belts are different along with the spacings
they only make them for the rb26. The power steering pump doesnt line up properly, need to shim the pump forward about 6mm roughly. When you fit it all up you will see exactly what needs to be done.
  • 1 month later...
