Nope, moderate launch but 3rd didn't like the heavy bit of my triple plate. Clutch+slightly reckless engagement=smashed 3rd gear. The previous owner broke 3rd on two boxes though 360-370awkw it might be time for an upgrade or more controlled shifting practices.
Thanks for the link but unfortunately it does not include transfer case. After speaking with Shaun at Boostworx it has come to my attention that there is more to it than just bolting my old transfer case to the new box. There is a fair bit of set up work involved.
Edited by fieds83
Yeh i have the serial numbers from both. Physically the series 3 has stronger synchros and smoother shift. There are a few other minor differences.
When i asked about the Kansai box and its shift quality i was told it was unknown because there was no shifter attached. I am happy to buy the box but i need to know if it works or not.
only boxes that have been driven are going to be able to answer that and I doubt there's many of those at import yards
we dont lie here theres no point and we do offer cash back if you have problems on start up
my 33 gts-t box felt fine on the floor in the car is a different story 3 gear syncro is alittle worn and I have to shift slowly
alternatively get boostworks to give it a quick check over before install
You've got rocks in your head if you don't clean out all the shite in a engine or gearbox or diff after buying from a import wrecker! And that is no disrespect to any of the wreckers out there, most times they don't even know the background of the part. I'd be getting it stripped down and rebuilt before it goes in anyways, don't wanna have to re post this 6 months down the track do you! Better be safe than sorry!! As they say, "when in a hurry, shite turns bad, BUT you've always got time to do it the second time"
Thats what i am weighing up atm, do i rebuild with a strong gearset or be gentle on a good second hander? Dont worry i had no intention of installing a box without a thourough checkover first. Still thinking about it at the moment, if only i could find a good condition stock gearset then i would rebuild my current box.
Edited by fieds83
    • Oh and I lost my headlight washer jet cover!
    • Ok, so I got myself some X1 wheels really cheap to try out, they're a bit different and I like them but they're really narrow (18x8) they are available in staggered 18x8/9 also but really hard to find.  I kinda dig them, but not as much as the F10 19's I usually run, so these go into the wheel pile.   As I mentioned in another thread, I got a new exhaust. It's an off-the-shelf stainless one that fits OH-KAY. I don't love the tips size and how far they come out the back, I think I might cut the tips off and replace with some smaller (~3") ones that don't extend as far. It sounds really good though, I'm not sure if its just in my head but the car feels a little quicker, more responsive.    I fitted an eBay special front lip. Surprisingly it fit perfectly and all holes lined up. Its a little rickety but I haven't put any double sided tape on yet, I want to clean the front bar up where it has scraped the road a lot and fil in the number plate holes (or, get body coloured wrap to cover them - is this a thing?  I'm not sure if I'll leave it gloss or pain it matte. I really like it though, I don't particularly like the front bar without it, I don't really like the M-Sport and to get anything else is just too expensive. That said, I might need a new one now anyway as I dropped the car onto the jack after forgetting to put ramps under the front wheels. It bent a lot and while it did go back to normal after I got the car off the jack, I do fear I have not done it any favours.   Lastly, my headlights died. Different problems in each. They have gotten much dimmer over the past year or so, I put new (uber expensive) OSRAM bulbs in them but to no avail. One of them pointed at the ground and the other just kinda did its own thing with light working sometimes. Yeah, check this 18 year old BMW headlight wire. I reckon I know why they were stuffed.       BTW, the yellow and black is the power to the Xenons. Yikes. I hunted around an researched my options here. I would have loved to just get a replacement harness but not a thing. My car has adaptive headlights, that is they rotate left and right with the steering wheel. Good condition used adaptive xenons were over $700 each, non adaptive were around $400 each, but I couldn't help but think that they're all around 18 years old now, surely they'd have the same problems. So I looked at newer LCI headlights but they were even more expensive and I couldn't confirm that they'd be plug and play with lots of people having lots of opinions so not worth the risk.  I ended up getting brand new Chinese headlights from MARS. They're very close to OEM with only the angel eyes being a bit different. I didnt want crazy turn signals or sharp DRL's or anything. Not my bag.  They're not adaptive, I thought thats a feature I wouldn't really miss. So I coded that out.  The lights are awesome, they look so nice and they take so many years off the car. The angel eyes look great and the headlight brightness is ridiculous. I was so used to the old ones, I didn't realise just how bad they were. The new ones use the OEM bulbs, Xenon ballast and leveller motor which I was happier with. The only issue with them is that the rear cover is held on by SEVEN screws. This will be a nightmare to get to and open when I need to change bulbs.
    • Now that you mention it I can see those too. More subtle. The lighting and low resolution makes it hard to assess super well what's going on but what is visible is bad enough to pull the motor.
    • I feel like this is due an update
    • Yeah, I wasn't giving two f**ks for the ring running around the bore. I was looking at the vertical scratches running up and down across the hatch marks.
