If the car has broken a couple of stock gearboxes at its current power level, IMO you'd be a madman to put another stocker in there, it's just a waiting game until it goes again.
A wise man once told me - buy cheap, pay twice.
Hope it all works out for you though, no-one likes their pride and joy to be off the road.
hey mate i can get you a 89 32 GTR gearbox for 450 !
you have to swap the bell housing, or just swap the whole gearset
its the cheapest way to do it
and you never know what you will find inside the box
a mate bought a 32 one and it had been changed to the series 3 33 GTR box already
BONUS
let me know if you need a contact mate
mike
couldn't agree more R33 were notorious fro breaking 3rd
Steve @ Manta Racing knows his skylines he rebuilt my front diff without even taking the engine out everywhere else was saying ah that job the engine has to come out and you could eat your lunch of the floor of his workshop very tidy and meticulous
The gearset is going to take around a month to be delivered, i would like to put a stock standard box or gearset in fot the meantime.
If anyone knows of an 32 or 33 gtr boxes around cheap then let me know as i'd like to put one in this weekend.
Cheers
Finally got a new gearbox without the trouble of waiting for it to come from overseas. The box is being assembled as we speak and consist of an OS Giken close ratio gearset with upgraded input shaft, all new synchros, bearings and seals. Just could not bring myself to buy some worn out wrecking yard box with unknown history. Basically paid the same as it would cost to build one here but i dont have to wait 3-4 weeks for parts to arrive from Japan and then assembley time, labour costs etc. Looking forward to the added reliability.
Mate these set-ups are great...we run one in our racecar and you would be hard pressed to tell the difference from a stocker. We just ran a 9 sec pass at the drags with ours and although i dont punish it, its seeing almost 500AWKW and holding up well. Synchro maintenance is the key to keeping them together.
Sounds good and will more than meet my needs.
What oil do you run in yours? I was using light weight shockproof in my last box but i have heard mixed opinions. It takes all the noises away in a worn box but when you dismantle a box that has been using it, the oil is stuck to everything but the gears.
DONT use redline shockproof in a new synchro gearbox....a good quality 75-90 gearbox oil such as Castrol Syntrax will do the job. Redline Shockproof is not suited to synchromesh gearboxes.
    • I have a heap that i have collected if you want some authentic ones still. Pm me if your interested!
    • Hey lads, reviving an old thread.  As an update, since the last time replied to this thread, ive done mostly suspension. Havent touched the motor except for maintenance. Though upon changing spark plugs, found out i had splitfires pre-installed! Updates: - Got me some stock airbox top cover and snorkel to fit onto the original intake. Should be free of defects - Bought a set of R34 GT-T brakes (not installed yet, going to rebuild + respray in champion blue + white 'Nissan' text) - Bought the last set of bilsteins from @Sydneykid and had them installed. Has been making some sounds on the rear but hopefully should be sorted out after this New Year break. - Regreased front caster rod bushings (poly bushes..) - Rear upper camber arms - Whiteline sway bars (BNF27Z 22mm + BNR11XXZ 24mm).  The rear sway bars are a bit short (ive read 50mm else where) but was still able to get them in.  Anyhows, I reckon suspension is sorted now. Maybe replace bushes (do have a set of front upper control arms from SK not installed yet) but should be okay for now. From now, I'm wanting to start working on the motor, drivetrain etc etc. Still debating on the order to go on and what to buy etc but: - ECU ( Haltech or Link ( Link states that it dont support A/T or AWD functions... Can anyone attest to this? ) - Highflow turbo ( ATR43ss2 ) - Intercooler ( Not decided yet, but cant find many good afoordable ones. Toshi says to opt for crossflow Japanese. Bit difficult this one, unless I get a returnflow Blitz from JJ? ) - Injectors ( Any recommendations ? I do have a nismo FPR ( Thanks SK ) ) - Seats - Tune by either Toshi or DVS To be fair, I did consider just keeping the stock turbo and nistuning it. Sat in a mates stock N, that had something like 200kw, and I reckon that felt more than enough. Maybe I should just go this route ahhaha. Too many choices.... Planning a trip down south, so wanting to just clean things up and make sure it gets to and from in one piece. Anything else specifically I should do before ? Cheers lads
    • Must be for the car’s lucky charm 🤷🏽‍♂️ She runs fine, but it just seems to take about 1L less. Maybe I’ll have the oil sump dropped at some point to check if there is anything
