IMHO with you running that sort of power I'd go an OS replacement gear set...with the initial parts cost plus fitting it won't be too much more than trying to find a GOOD s/h series 3 box.
If moneys is short just replace with a good 2nd hand series 1/2 box....
If money is not short, how much should i be looking to spend on a gearset?
I just found a series 3 box for $1,100+ freight which i thought to be pretty reasonable but i dont want to keep doing this over and over. The previous owner killed two boxes before me and strangley enough they have all been in 3rd gear. I am sure my triple plate clutch is not helping the cause.
Edited by fieds83
Transfer case isn't worth that much... you can swap yours onto it.
The power your running isn't killing the boxes, it's either the clutch or your driving style or both. Chances are it's the clutch killing the boxes. You could put a OS Giken gearset through your S3 box, probably cost you between 3-5k.....
Yeh, just checked greenline and they have 5 speed cross mission gearsets on sale for $2,480aud. So i would be expecting $3,500-$4,000 fitted.
Thanks for the info, the clutch is copping most of the blame in this instance though i have to admit it happened in the heat of the moment.
yeah, i had 300awkw for 18 months no dramas. re-tuned to 376 and smashed 2 of them within a month. got a ppg now. so ya a os gearset is the go. and since yours is a s3 you dont need to get the upgrade parts from nissan.
it will be cheaper in the long run. they are about 2.5k for the set. with the input shaft.
yeah. i have run a os twin, nismo twin, both damperd. nismo tripple and a r3c os. all without issue untill the power rose. my frst one(route6 ) stripped the input shaft gear.when changing to 3rd. and the second standard gearbox smashed all the teeth of 3rd after ONE QUICK change.
I think you would be doing pretty well to get a good series 3 box for 1100. The trouble with 2nd hand boxes is that unless you can open it up and look before you buy you are never sure what you are getting.
For the power you have listed and you have $3ish k to spend without doubt go an aftermarket gearset like an OS....I've seen way too many std boxes in GTR's break with that power (granted it was track use). If you don't have the money then try an find a good condition 2nd hand R33 box and as long as you don't have a solid center clutch and are fairly gentle with it it should last a while.
All I know is that the series 3 boxes have stronger syncros and a few other strengthened bits....maybe someone else here could provide part no's or something to identify them.
  • Like 1
I don't know if it helps but here ya go:
Series 2 box:
Part Num: 32010-12U00
Series 3 box:
Part Num: 32010-12U10
Nissan list 32010-12U10 as the "alternate part" for series 2 but list 32010-12U60 as the alternate for series 3 R33 GTR.
Looking inside the box itself theres a load of parts to compare and im lazy.
Series 2 box:
Series 3 box:
Thanks for your help Kris, hows your gtr going? Did you end up with those GTSS's?
Buying them soon - heading to Japan in January and picking them up there.
Car's going well though.
You bought a S3 now? You found one you liked?
Yeh, got a good deal on this one from a forum member. When i rectify this gearbox issue i will transport the car upto Mackay as my dad just bought a house there so now i have somewhere to keep an extra car. Was thinking to go 34 but this one has some tastefull mods and was a lot cheaper. As it happens my mate wants to sell his 34 at bargain basement now, its very tempting but i just bought this car and i am not ready to let it go.
    • Hi guys, has anyone either purchased or built themselves a rotisserie for their car before? I can only just justify the need for one hence why I should just make one but at the same time, if I make one I can kiss another 4 weeks of potentially productive car working time goodbye because I'm building a bloody rotisserie....  I mainly want it for the application of the body deadener.  Cleaning the old stuff off, priming and then colour over the deadener doesn't worry me, it's just the application using the Schutz Gun that I feel would achieve a significantly better finish painting it side on and keeping the Schutz Gun upright.  I don't think they would work well on the side let alone almost upside down for some areas.  If the product I use (Terosun, etc) could work through a HVLP ok then it might be ok to apply without the rotisserie.   I can get one of these style ones for about $1200 which is pretty good value-     I reckon if I made one it would cost around $500 but it's more the time that it would take is more of a killer than the cost.  They look to hold their value pretty well second hand so I could always sell it after using it and realistically only lose $200-$300 at worst.  Or keep it and buy another project when this one finally sees the light of day... Anyone selling one...? Cheers!
    • While it is a very nice idea to put card style AFMs into the charge pipe (post intercooler, obviously), the position of the AFM and the recirc valve relative to each other starts to become something that you really have to consider. The situation: The stock AFM is located upstream the turbo, and the recirc valve return is located between the AFM and the turbo inlet, aimed at the turbo inlet, so that it flows away from and not through the AFM. Thus, once metered air is not metered again, neither flowing forwards, or backwards, when vented out of the charge pipe. When you put the AFM between the turbo outlet and the TB, there is a volume of pressurised charge pipe upstream of the AFM and there is a volume of pressurised pipe downstream of the AFM. When the recirc valve opens and vents the charge pipe, air is going to flow from both ends of the charge pipe towards the recirc valve. If the recirc valve is in the stock location, then the section between it and the TB doesn't really matter here - you're not going to try to put the AFM in that piece of pipe. But the AFM will likely be somewhere between the intercooler and the recirc valve, So the entire charge pipe volume from that position (upstream of the AFM, back through the intercooler, to the turbo outlet) is going to flow through the AFM, get registered as combustion air, cause the ECU to fuel for it, but get dumped out of the recirc valve and you will end up with a typical BOV related rich spike. So ideally you want to put the AFM as close to the TB as possible (so, just upstream of the crossover pipe, assuming that the stock crossover is still in use, or, just before the TB if an FFP is being used) and locate the recirc valve at the turbo outlet. Recirc valve at the turbo outlet is the new normal for things like EFRs anyway. In the even of a recirc valve opening dumping all the air in the charge pipe, pretty much all of it is going to go backwards, from the TB to the recirc valve near the turbo outlet. But only a small portion of it (that between the TB and the AFM) will pass through the AFM, and it will pass through going backwards. The card style AFMs are somewhat more immune to reading flow that passes through them in reverse than older AFMs are, so you should absolutely minimise the rich pulse behaviour associated with the unavoidable outcome of having both a recirc valve and an AFM in the charge pipe.
    • Yep, in my case as soon as I started hearing weird noises I backed off the tension until it sounded normal again. Delicate balance between enough tension to avoid that cold start slip and too much damaging things.
