Hey
Can anyone tell me the difference between a R33 GTS-T 1996 series 2 and R33 GTS-4 1996 series 2.
I know the gts4 is 4WD Turbo (and so it handles like a gtr) if it has GTR 4WD transmission.
Also price differences etc. (r they cheaper for eg?). also if u wanna convert to rwd how much, pros, cons etc. .
the one im interested in is a RB25det conversion and is a 2door- and asking price is 11g's. advice plz
Cheers
Edited by Gold 180
https://www.sau.com.au/forums/topic/188373-gts-4/
If you really want to go through a conversion to RWD, you'd be better off saving yourself the trouble and looking at GTS-Ts' rather than GTS-4s'.
You'd be able to pick up a decent S2 GTST for maybe 14-17k
sorry for not directly answering your questions by the way.
https://www.sau.com.au/forums/topic/188373-gts-4/#findComment-3396913
Thats correct. Only R32 GTS-4's came in a turbo version. R33 GTS-4's only came in non-turbo, so if you find one, it has had an engine swap. Engine would have come from a Stagea most likely as a GTST RB25 wouldn't fit due to the front diff. The whole sump is shaped differently.
It may also be an RB25DE + t which you should look out for. If it is a non-turbo engine with a turbo wacked on, you will be very restricted with mods mainly due to the higher compression ratio.
https://www.sau.com.au/forums/topic/188373-gts-4/#findComment-3398016
also with the r33 gts4 if you put a conversion switch in them they arent constant 2wd all of a sudden they will switch back on something to do with the front driveshaft but with the r32 gts4 its all good i just swiych on 2wd and its stays on untill i turn it off
https://www.sau.com.au/forums/topic/188373-gts-4/#findComment-3403861
Not quite right mate..
With the 33 and 34 4wd systems, there is always a certain amount of preload on the transfer case, so turning off the computer doesn't remove all the mechanical link. Therefore if you throw a 33 or 34 on a 2wd dyno and only pull the fuse and expect it to be ok, you will most likely toast your transfer case clutch pack.
It doesn't all of a sudden come back on...
james.
https://www.sau.com.au/forums/topic/188373-gts-4/#findComment-3406189
