FFFFFFFFFf**k i hate cops, just got my work car defected to cop shop and a $325 fine for driver licence out of date by 2 days and 2 cop cars were called couz they thought i was doing a runner and only 4 streets from home. Then they pulled over someone els right infrount of my place and when i walked in my driveway they both gave me a smart ars look.
and now iv got 1hour to get the car home or they tow it and i cant drive till i get my licence redone and cant do that till 2moro so im venting like a s**t on heat so im gana go drive it home now and smoke it all the way homeeeee f**k it after a 9 hour day busting my guts and to deal with 2 noob head cop make me walk home im gana rip that road up!!!!!!!!!
Im relexed now lol no burnouts but got the car home. When i take my car to the cop shop can they do me for anythink els couse i got done for bald tyres, no battery clamp and over flow bottle not clamped to chassie but its got so many other things wrong like frount is very low and a million other things
was he on the phone matty or you dont know .... police can check records ;)
i kno its been 5 days since ya said that mate, but i was the one on the phone, and stopped at the time. Was on the phone to ben (r31_drift_pig) at the time and he heard it too (and some of my expletives that followed)
so far, quotes of $1500 to fix :P
goin to get my insurance to sort it out
Hi jess and friends, you able to get a quote for rs4 front hubs and r33 rear hubs, i got a quote here for $75 each for rear's
Hi I will suss it out and let you know
But more then likely it going to be more cause of postage :D
went and saw linkin park last nite was pretty mental
bastard, i missed it cause work said i wouldnt get the time off, didnt end up working either. *sigh*
as a side note, i think 'for those that dribble' under the main title should be replaced with 'for when looking at porn gets boring.' :P
edwardstown. looking at getting coilovers but r34 ones dont fit cause of the rear shock is a fork so need 2 find if r33 fits all round.
u got some laying around Steve i could borrow? shouldnt take to long i hope.
hahaha Joel i lol'ed
and F1 Dan
i would imagine R34 would be better from what i can gather is there is only one sort of suspension on the skylines no difference between turbo and non turbo
but your welcome to find out the hard way
EDIT
yeah Luke do you work ... come up this way and we can go to my tire guy and get it sorted
    • 49719 is the cooler loop. Right at the front, LHS of that diagram. Return line from rack (LP side) goes to cooler loop on RHS front of car, then back under engine and returns to bottom of tank. 49717M is feed from tank to pump. HP line out of pump is thick rubber, followed by the hard line that runs down to crossmember and runs in parallel (but opposite flow direction) to the LP return line. Nothing goes anywhere near the firewall or interior of car. The closest they get to that is the connections on the rack.
    • Thanks, plan is to drain all fluid tomorrow and do smoke test to find out the leak.   Appreciate your help and want to understand how the system work. So cooling is achieved by the long loop not any rad? The diagram seems to suggest it connects to somewhere inside the cabin and I thought that is a cooler inside firewall. If you look at the diagram it seems to show it connects to something inside firewall. I tried chasing it but not easy unless I take loads off   i am confident pump is good as fluid goes in and it gets soft( steering) but as soon as I turn engine off , loads of bubble come to surface and overflow. When engine is on , fluid level is below minimum but when off it shoots off and thinking it is sucking air in. I suspect aluminium pipe may have a crack line or whole   smoke test with no fluid should be a good start and if needed will remove the pump   In addition, the one going under the engine bay is high pressure line and one directly connecting from pump to resorvoir is return/ low pressure?   finally I searched and suggestion is to use dexron 2 but that is discontinued so bought dexron 3 as all research suggest it is compatible and shouldn’t cause any issues/ blow seals. I bought two liter of dexron 3 motul atf
    • Don't worry about. Just don't try to drive hard enough to make boost and you'll be fine.
    • Yes. This has already been said. It is a loop of hardline in front of the radiator. Because.... the pump is on the LHS and the steering rack hydraulic connections are where they always are on a RHD steering rack....on the RHS. The high pressure line goes down under the engine, along the crossmember, like it does on all Skylines. Don't just throw expensive braided hoses/other kits at it. Work out what is wrong and fix that.
    • Still got the afm on the intake, clamps are shut tight, only loose hose is the one that goes from the j pipe towards the IACV, since it's next to impossible to find a factory hose and the barbs are different sizes (I'm still using clamps on this hose to try and help it seal on the iacv side) I've ordered parts to make up the hotside of the intercooler pipes, I'll plumb it in and see what happens in a few days I suppose The turbo's internally gated, can I just unscrew the tension rod to let the gate open?
