Some pics from the start of the Climb To The Eagle this morning (before heading off to work :( )
There were a heap of clubman style cars there (as their nationals are in adelaide this weekend) but I didnt bother with photos of them, they do nothing for me :P
Sif you got no evo pics lol
was at work 2day driving the forklift and some little kid was through rocks at me. must of bee like 3 or 4 yrs old. little shit.
Unley nissan FTW also, gave me like 6 bolts i needed for my car for free
Also, anyone driving/cruising tonight?
I wonder why :)
:spank:
Omg they usually dominate hill climbs lol.
And woohoo paid to go do my gay as learners course today for bike licence, and I found a very very sweet evo that I think im gonna get.
Edited by sinistagtst
i saw the R8 coming down belair rd back to the audi dealership this after noon.
also spotted a nice BMW M1 was that up there looked like it was heading back from that direction
oh yeah and the Sierra DROOL -- the entire reason i like cars so much Group A FTW
Edited by Whiplash
^There were two BMW M1's there this morning, a blue one and a white one with M stripes on the side.
The sierra was a RS too, but the interior had definately seen better days though :P
Ahhh, the good ol days at Mallala, destroying commies with ease! Group A FTW
My Dad is a ford man, so the Sierra was just the next evolution for Ford in Aust.. Dick Johnson was my idol when I was 7-10yo (87-90) LOL
Then with GTR Dad (and I) were a nissan converts till they went V8supertaxi, then it was back to ford. (and DJR)
been a bowe and seto(until this year :P) supporter from when i was 5, so looks like i have to start supporting some else next year with JB retiring. Been a fan of Bright for a number of years now so i'll continue on with him
    • 49719 is the cooler loop. Right at the front, LHS of that diagram. Return line from rack (LP side) goes to cooler loop on RHS front of car, then back under engine and returns to bottom of tank. 49717M is feed from tank to pump. HP line out of pump is thick rubber, followed by the hard line that runs down to crossmember and runs in parallel (but opposite flow direction) to the LP return line. Nothing goes anywhere near the firewall or interior of car. The closest they get to that is the connections on the rack.
    • Thanks, plan is to drain all fluid tomorrow and do smoke test to find out the leak.   Appreciate your help and want to understand how the system work. So cooling is achieved by the long loop not any rad? The diagram seems to suggest it connects to somewhere inside the cabin and I thought that is a cooler inside firewall. If you look at the diagram it seems to show it connects to something inside firewall. I tried chasing it but not easy unless I take loads off   i am confident pump is good as fluid goes in and it gets soft( steering) but as soon as I turn engine off , loads of bubble come to surface and overflow. When engine is on , fluid level is below minimum but when off it shoots off and thinking it is sucking air in. I suspect aluminium pipe may have a crack line or whole   smoke test with no fluid should be a good start and if needed will remove the pump   In addition, the one going under the engine bay is high pressure line and one directly connecting from pump to resorvoir is return/ low pressure?   finally I searched and suggestion is to use dexron 2 but that is discontinued so bought dexron 3 as all research suggest it is compatible and shouldn’t cause any issues/ blow seals. I bought two liter of dexron 3 motul atf
    • Don't worry about. Just don't try to drive hard enough to make boost and you'll be fine.
    • Yes. This has already been said. It is a loop of hardline in front of the radiator. Because.... the pump is on the LHS and the steering rack hydraulic connections are where they always are on a RHD steering rack....on the RHS. The high pressure line goes down under the engine, along the crossmember, like it does on all Skylines. Don't just throw expensive braided hoses/other kits at it. Work out what is wrong and fix that.
    • Still got the afm on the intake, clamps are shut tight, only loose hose is the one that goes from the j pipe towards the IACV, since it's next to impossible to find a factory hose and the barbs are different sizes (I'm still using clamps on this hose to try and help it seal on the iacv side) I've ordered parts to make up the hotside of the intercooler pipes, I'll plumb it in and see what happens in a few days I suppose The turbo's internally gated, can I just unscrew the tension rod to let the gate open?
