Thats a bummer.....hope you didn't have too many troubles buddy.
Did you eventually see what the problem was with the old one?
na the old one is still on my car
Good day eh Steve? Bet you are itching to get that new turbo fitted!!!
yeah :) cheers heaps for your help will get it fitted Tuesday evening :D, will sort out a time for me and shannon to get the fuel pump in my car also dont need it detonating on my way to melb
better leave a trader rating for you :P
ive asked this question elsewhere, but to no avail. Need some advice from anyone running an RB20DET, and using an aftermarket oil pressure gauge.
finally got my oil pressure gauge in on the 31. Did an oil change while i was at it (naughty me, 2 practices on the same oil and she's black as hell). Admittedly i changed my grades of oil (as i had some sitting around from drift school) - gone from a 10w30 to a 20w50...........wouldnt have thought that would make THAT much difference tho
started it up, pressure started at 30psi..........after about 30sec i hear a warning beeper going...........look into the cabin and see the gauge at 2psi.........turned it off, checked under the car (no leaks etc, nothing wrong). Started it again (mind u, its running EXACTLY like it always has), back at 30psi, and after about 15sec the oil pressure is dropping off back to 2psi again
im confused. is my gauge knackered (its brand new), is my sender knackered? I know it couldnt be a true reading as for that low a pressure the thing wouldnt be turning over. There aint no death rattle, nothing like that. Wont get a "legal" chance to take her for a drive on the street till at least next Monday, so wont know how it behaves under load until then.
any advice/feedback is appreciated
fk i hate it when im the office scape goat.. i organise stuff... the ppl involved don't communicate, then i wear the fall out when the customer shows up and the sales tard turns around to me all like wtf where is the techo??
sales guys sh*t dont stink, and they have no honour...
techo's are delicate genius' needing everyone to tip-toe thru the tulips. and feign not understanding things if its 1/2 way laymans terms...
and both only pay attention to procedures when it suits them.
/rant over.
i feel better now
never a truer word spoken! i'm just being a bit picky atm thats all, have blanketed the job market wif my name, had a few offers but they weren't up to par. What i am working towards is joining the defence force, the corporate environment is not for me... been thrashing myself into a resemblance of fitness :P
up hill battle but im getting there
/rant over.
i feel better now
hmmm that sounds familiar...... hence the fact i quit last week
nos only last so long and nos will still blow your engine
meh. have u seen high octane? they did an experiment on an r31 to see whether they could blow the engine with nos took a high amount of hp before it blew.......................was quite funny tho lol
i dont even keep the bottle in the car so its all ok............. im not that stupid. its for dyno and track use only.
have been told tho i can get defected for the lines *touches wood* hope it never happens tho.
Better off turbo'ing it..
Voids the insurance exactly the same but at least you may get away with it as the cars are released with turbo if your ever pulled over. + then you can use it all the time. :(
Even still a ~100hp nos is bugger all; you'll still have a stock rb25det with a pfc sit side by side if not whoop yo ass. :D
150hp you may pull away but very slowly.
We don't have a track nos can be used at. ;) One day AIR will reopen for drags.
but why should i be like every one else who has a turbo'ed car? honestly what ever happened to uniqueness??? i dont want to be like every else.
and im sure if i ever take on a stock GTT i would be able to keep up i too have a power fc. i have many plans for my car, and none of them include a turbo.
and what about mallala?
    • Hey all, I did a voltage test with the car (video attached) not running for 3 days. And here is some interesting stuff: - Battery voltage is 12v (I had the key in the ON position) - Drops to 9.76v while cranking then quickly goes up to 14.5v - You will notice there was a sorta slow start but not as slow as it usually is. - Idle surprisingly was better at just over 1,000rpm instead of 1,100 rpm. - I turned on the A/C, radio and headlights in the video and the voltage remains the same - I haven't cleaned the grounding wires on the chassis yet, that's next. - Battery drops to 12.6v when I turn off the car and wait a bit Seems like I might have a parasitic draw? I do have an immobiliser system which does drain the battery more of course but was wondering if there is anything else I should be looking at fixing? Does the ground wires on the chassis have anything to do with the low 12v?
    • My lord that is some low oil pressure as minimum in the manual! I guess the big part will be seeing how it changes as the engine gets more spirited use.
    • Turbotapin   so I am about to be mounting mine up been waiting for the body to get finish at paint. I had a question. I was told our Speedo sensor it originally in the transmission but the cd009 is in the diff on the z. How did you get around this?
    • I definitely do recommend having a fab/grinding/dirty shed or area to keep all that grinding dust out of your main shed.  But you're right, it doesn't matter how much room you have you still end up filling it! I might even do a short video which will make it easier to fully take in the horrors of what I've created...
