it seemed to be moving much more lateral down the street than usual also the driver was wearing sneakers FOR SNEAKING
nah as i said it was probably nothing, driver jus seemed a bit short with me when i was talking to him at the lights but yeah he may have been jus having a bad day
if there's no black 33's missing dont worry about it
edit: actually jus had a look back at threads n seen the last 2 black 33's that got stolen, wasnt either of them. well the wing was stock gts wing n had diff rims so not without a decent amount of work to make them look different.
never mind was probably nothing
Edited by gzilla
hehe nice photos! :D
BDO was awesome by the way!! Bjork.. WTF?! Apparently she was singing in english? Just looked like she was having a fit on the stage, running around throwing her arms in the air.
hahahaha i was waiting out the front for regan to pick me (cant believe he brought the skyline - with all the cops around and all) and i could hear her sounded like a cat drowning................
Needs VS-KF's hanging about 8 - 10mm out the guards, Heavy flare on the rear, slight roll and flare on the front, and lowered another inch.
Hang on, I own a R31, why are you listening to me LOL :banana::down:
Carry on.
(Oh, and very nice 34 BTW)
    • Welcome Gabriel, and thanks for saving one of the less famous cousins!
    • Wanting to avoid this if possible but kinda looking like I may not have a choice 😭
    • Ok awesome thank you. Just wanted to have them in case I can find some and need to compare part numbers!
    • All I can say Duncan is good luck and I hope that Neil did not run any E85 in Cheryl. I have recently experienced the full spectrum of fuel tank issues in my R33's that had been caused by E85 and contaminated fuel. When you take the cover off the top of the tank and have a look inside you will get an understanding of how easy it will be. Best case situation is clean fuel with minimal contamination. My GTR was like this and it was a very simple operation to just grab the fuel pump carrier bracket and slide it up and out of the tank. My three GTS_T's had different levels of fuel contamination that was probably caused by E85 in the fuel.  In the worst case all of the metal components in the tank had rusted to the point where there were pieces of rusted metal swirling around in the tank. This required the removal of the exhaust, the tailshaft, the complete rear cradle and the fuel tank. The components in the tank were that rusted that it took days to get the fuel pump carrier and the mounting brackets out of the tank. When the tank was finally cleaned, everything inside the tank had to be replaced. With the tank all back together I could then reinstall it in the car along with everything else that had to come out. Good luck and I hope that you find a clean tank.
    • It is a two door. It is black and also still has the OEM wheels and stereo. Exact model would be KR_R32RGFEL_SS According to GTR-Registry.com is a 2 Door Coupe; RB20DE; 2WD no HICAS; MT.F5; (11L) Projector Headlamps and Fog Lights; (12_) Electronic Active Full Auto Air Con (Climate Control); (13-14SS) V Selection -- Which seems to be accurate description of my variant. Will try to upload a few pictures soon. The OEM wheels look like the below image. Image is taken from the goo-net-exchange website.
