The Sa Wasteland
Cubes
 Share
:blink: thats to the docks and 12g usd
but even still would get it to aus in under 20g landed and possibly complied but as Ben said you may need to redo the front end to original spec
Car will have to be returned to COMPLETLEY stock.
430hp indicates new turbo(s), fuel system, exhaust, FMIC, engine build, Management/ECU etc.... all have to go back to standard.
Compliance - $5K plus getting all the stock shit.
All the freight charges/import taxes/duties etc.
be looking @ $20K - $25K after all that +tyres/Inland transport/rego etc.....
Cheaper and easier to buy one here. :blink:
so how is your car Jess only minor problems i hope
Did a CV joint Thursday night coming home from work :(
So couldn't put on in in time to do the trip..
Took the proton instead but found out the shocks are dead in it...so didnt make it a fun journey 800km on the Highways :D
Only made it to Melbourne...and decided to drive back home :blink:
I will be over in a few weeks for a weekend so will catch up then!!
Wonder if some of your guys would be interested in entering DECA in May at Shepparton??
All that shit still has to be done. IF you can find one for $6-7K (which is going to be a tall order, theey're still 10K there....), still going to be $15K by the time you get it just READY for rego. add in rego/tyres/on roads/inland transport etc and you still nearly on $20K. And you're starting off with a stock car.
Buy one here already modded and ready to rock and save the time/hassle/headf**ks and the 3 month wait. If you buy one from interstate still cheaper than bringing one of your own over....
Edited by R31 drift pig
Sweet! Heard good things about those turbo's on 20's.... f**king hard to get hold of though. I know where there's a complete RB20 kit, but it's $2K or something stupid, So I went with a trust turbo.
You changine injectors/AFM/ECU at all?
Id add a Z32 into the equation and shoot for 220 - 230. Those turbo's are capable of 250...... and reportedly VERY responsive on a 20..... sounds like it's gonna be a stomper setup though.
Im basically running a similar setup with my TD0620G 8cm (Walbro (soon to be 044 and 2.5ltr surge tank)/FMIC/exhaust/DMAX manifold/GTR injectors/Z32 AFM/Boostworx Remap/RB25 box), and shaun tuned a similar setup on a R32, 241kw's on 16 psi, full 16 psi By 4000rpm. Ill be running 1.2/1.3 bar and a 8500rpm limiter.... Hoping for a solid 250.
 Share
    • Best bang for buck at the moment would be a 86/brz. Good chassis,  plenty of aftermarket support and parts everywhere.   I just picked one up with some quality gear and it drives better than my old 180sx.    Also depending on what your doing and budget.  An a90 supra is my pick if want to spend more. Great chassis, solid motor, gearbox is good. Development potential is crazy. They are doing well in prod sport and time attack. All the old jdm stuff needs alot of work as most of it all bent and over priced.
    • It's basically the same platform, hence why everything bolts to everything else Kelford camshafts were recommended by Mania after they asked me what I want the car for, I said "I'll thrash it around daily and maybe take it to the track for fun" 🤣 Factory NC 2.0L cam specs: - Adv. Dur. 256 /256 - Dur @ .050 205 /190 - Lift 9.42mm/8.13mm So, as I know nothing about cam specs, all I can say is the numbers are different and it should get a little bit of lope....🤣
    • Depends on how extreme, however if you look at SMSP, they're all dominated by Hondas and M cars on amateur/street car events.
    • Without better pictures, it won't be possible for anyone to work it out further than we have.   Start measuring, EVERYTHING. Thickness of flywheel, and all around it. You want to know is if everything parallel. If from the face of the pressure plate (that bolts to the flywheel) if it is parallel to the pressure plate face, then something is NOT parallel or equal elsewhere. Or you've bent the shit out of the fingers in the pressure plate.
    • Finally getting around to changing whole cold side. (Look at that sludge) lets see where this leads once it’s all together tomorrow.
