Hey guys, im fairly new here.
just bought a 32 4door, heaps happy with it. Just needs a bit of love.
Anyhoo, just wondering. when trying to fit a standard front bar to a 32 with a cooler is there any tricks or things to do? I ask coz when i bought the car it came with a second front bar (first one was hacked to bits) second one wasn't it that much better con. I found that i have to cut a LOT out to get it to fit on, especially where the two side vents are, where the bottom silicon hoses join to the cooler.
I have seen a few 32 one here with coolers and their bars don't look like they have been cut around those areas. Maybe i need to mount mine different?
Any help is appreciated
Cheers, josh
Welcome josh, I recently fitted an intercooler to a mates 32 but he had the GTR front on it so it may be a bit different. We had to cut a fair amount to clear the piping on either end of the cooler but if ya take ya time and work out the right amount to cut out then you can make it look neat. Just a matter of not cutting too much out and following the contour of the pipes.
SLED, out of curiosity, what ECU are you using and what made you choose Martin Donnan?
got something interesting in the mail today, a 'certificate of exemption' and a south australia vehicle identification plate for the celsior.
anyone feel like clearing up exactly what a certificate of exemption is? lol
How many squids for window tint if you dont mind me asking? need some 20% all round for the 31....
yeah right. Bit pricier than what I was hoping for....
Well im getting my alarm fitted for $395 and he is doing my tint which is 20% for $220, So i dont know if its cheaper cos im getting both done, but Ric is a top guy, so definatly ring him up and say your Steves mate from SAU :) I'm sure he would be lovin all this extra work that wasnt part of the group buy........
I think because it was prob imported with that 15 year rule thingo, it prob didnt have to be complied like normal, so hence the "exemption" and the SA Vehicle Identification saying its all good.........
Thats what i read from it, but might be wrong!!
Iron Chef would know when he rocks in here next!!
Hey Ryan, I'm running a PFC.
Using Donan because he's possibly one of the best PFC tuners in the country, Jeff is another guy I would recommend .
Check what the guys interstate have to say about them http://www.skylinesaustralia.com/forums/Ke...43#entry3617443
I've heard stories about Martin that if you don't know him he doesn't give you his best.....can't really comment whether thats true or not but I know Pete Hall (other 1/2 of Willall Racing) pretty well and he has had a chat to Martin about me so hence the reason I'm going there.
Here is a link to my specs http://www.skylinesaustralia.com/forums/Rb...html&st=120 (scroll down the page)
hehe..yea thats what i had heard, you pretty much said everything. Its a shame peter doesn't work with willall anymore. I think im definetly going with Jeff for my PFC tune. cheers for the info :P
Pete is fisher performance AWD dyno and did they tune if for you
Only a 2WD but you can always drop your centre shaft.
I have realized that just because someone has a dyno, doesn't make them a tuner....read what you like into this but if you want further clarification I'll speak to you at Chalkers Sat night.
Yeah Martin had a quick look and drive of my car this arvo and as I suspected, its a bit of a mess.
I'll probably get Jeff to do mine as well because it needs to be re initialized and started from the begining, plus Jeff is just around the corner.
totally agree... my mate Michael and I are slowly learning on his dyno, finding many different procedures, ALOT of trial and error, managed some very good power with a very safe tune so far...mainly working with PFC's and Microtech, still waiting on my PC interface for PFC however.....but yea many procedures, safe guards to learn....alot of tricks and ways of not doing things are involved....takes hours and hours of playing with and with the right people.
Edited by Ryanrb25
Did you get your software from Access Autoworks on Ebay
http://cgi.ebay.com.au/Apexi-Power-FC-Comm...1QQcmdZViewItem
Me? nah, was too busy trying to get the R31 to even run. :P
I f**king hate the RB coilpack setup. Im going forward facing plenum and EA falcon coilpack, simply so I dont have to f**k around with it anymore.
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
    • I hope that is not something that bad. From what i remember he said that only first gear is "hard" to get in and that he has couple of ideas what to try next but idk 😕  hope it is not gearbox out. I will let you know.
    • If it's not the hydraulics, it is probably gearbox back out. Usually as per @Duncan's post, or otherwise associated with not getting the throwout fork positioned correctly. All the way up to catastrophically bolting shit back together without it being aligned properly and wrecking the clutch/input shaft/flywheel/something else.
