hey wats that double sided tape that ppl use to hold bodykits on?
the strong stuff? and i canget it from bunnings yeah?
i've seen it at car toys before, but you could use zip tie work just the same and probably be chaeper
Are you serious or just messing around???
Im serious if someone has the money. Everything has a price.... and there's more important shit to be done to the car ATM.
If no one has the money, it get's put on and run at low boost until I can afford to upgrade shit. With my missus's car officially out of action, I have to get it on the road ASAP.
You have money.... PM me. :)
As for the ziptie/double sided tape convo, use 2 small tek screws on the ends of the skits inside the wheel arches, and cabletie the front bar on.
As for R32 coilovers.... how much you have to spend? I know of a few sets ATM....
Im going to go die in a corner now. :P
i purchased some from the body shop on Pt Road. A huge role is like 15 bux or something....i used it for my rear pods...works very well, altho my kit is factory Plastic injection moulds...they fit snug as, with alot of fibreglass kits there will probably be a small contact area with the actual body so may be better to use tek screws..
Edited by Ryanrb25
AHAHAHA That was my other option when i was looking at plates for MY maroon 33.....LOL But stuck with the ol RBB 033, close but no cigar!! Now my mate will have those plates when he gets the car!! People may mistake the two cars!!
Haha great minds think alike!
And then there's girls........ Can never have enough of all of the above, but you gotta spend some of one of those to keep the other!! well actually both ;)
And if you want to know exactly how much she costs you then click!
(Possible re-post)
    • KYBs are typically twin tube, putting them in the lower tier of desireability. Do you just want to replace worn out ones for the lowest cost? I mean, you wouldn't just replace one end of a car, if the rears are a similar age to the fronts, then they are probably nowhere near what they should be, and likely won't be great against brand new fronts. So, to spend ~$800 on 2nd tier dampers, when you could get a decent set of MCA coilovers for <$4k.....? As to the strut tops. 1st up, the Sparesbox site specifically tells you that they are not correct for an R33. Beyond that, why do you think you need them?
    • That's not very Toyota of the Toyota!
    • Bringing an old thread back to life Looking to put some new front shocks in the r33Gtst and the KYB still look ok for a road car. Unless there are any other options aroind that price $200 a shock?  I’d like to replace the strut tops also, is this the correct KYB no. For the strut top, KSM7124?  https://www.sparesbox.com.au/products/kyb-strut-top-mount-ksm7124?srsltid=AfmBOoq-HDru8wSlLnQrhU9gCw_uYdKg8gUQzONY-EQOdnI5iXOWEUjY 341287 appears to be the front KYB shocks part no.  thanks all
    • LandCruiser used to get a fluid flush every 12 to 18 months.   Only because it was about that often the electric motor on the master for brake assist kept dieing and needing to come off.
