The Sa Wasteland
Cubes
 Share
I doubt you got good at everything ... but its good to see you learning. Just keep a straight head when driving.
you doing the log book system I hope. Taking lessons from a qualified instructor?
i did get good on everything.
well the instructor i have doesn't fill out the boxes in the log book
he does it on his sheet, but he fills in the time sheet that's in the log book
Had to run home during my lunch break to pick up something.
2 Common-whore and 1 Falcon wanted to race in 3 different instances.
I just ignored the f**kers!
Afterwards at the next set of lights, one of the Common-whore driver told me my car was slow ... I told him that he was just stupid. :thumbsup:
Afterwards at the next set of lights, one of the Common-whore driver told me my car was slow ... I told him that he was just stupid. :)
lol ive got a good one for everyone out there wanting to get out of a drag or if someone is giving them shit politely say: " sorry sunshine but my starter motor alone has more killawatts than your car"
thats probably not far from the truth.
Am I able to participate in cruises with my parents' Astra? :P
I'm sure I'll get left behind once I'd get to the Freeways/Expressways (hint: It's only 1.8L :) ) but I'd be able to enjoy a cruise for at least part of the way.
My favourite spots to cruise include the Hills and Clarendon, as well as the Southern and Port River Expressways. Note that I do live in the inner South.
Sorry Norm but no, where a Skyline club not astra club, in saying that get to know people and im sure someone may let you ride with them in the event there is a spare seat
cheers Matty got link please :)
madaz, mite wanna hav a watch of the HID group buy #2 as your name is already down ;)
I know a few people on here that might give me a ride :P
I'm glad that I asked though... could have been embarassing :)
Edited by normangerman
 Share
    • ..m'kay.... I see on my phone you're having difficulties interpreting the artfully hand drawn R31 wiring diagrams... you wouldn't credit it, but they're actually more accurate than those colour diagrams in gregory's and the like... ...for your purposes though, the wiring colour legend is on sheet 1.... ....the fuel pump connector is top right on sheet 2.... ...pin1 (black) goes to chassis ground -- pin5 (light green/red trace)... The best way to navigate those drawings, is to open them up in whatever image manipulation/paint program you like, and use the straight line/ruler  tool (with a highlight colour) to trace along the wire lines...not hard, no rocket science involved... Fun facts: The OEM diagrams are drawn to top trim level spec ~ so for example, you're looking at Silo spec wiring, but the base S3 Executive trim is also covered by the same drawing (base models just don't have all the add-on luxury bits) One of the more sublime bits of errata, is this bit... The wire splice between pins7,14 doesn't exist (red) -- the bridge on the cluster PCB between the same pins (green) does exist...but it's not 'there' physically...it's actually more towards the center of the PCB, exactly at the spot where they tend to crack...and if it does, only half the dash lights work... can drive you nuts chasing it ; don't ; just solder in the missing splice... These are 'intentional' soldered and taped splices inside the loom(s) ~ there's also unintentional splices like this, due to manufacturing process when a spool of one particular coloured wire runs out, and they splice in/on a new spool. Those splices above are in the loom, LHS, underneath the front guard panel (remove to get at loom)... if water's gotten into the looms, you can expect corrosion at these splices ... keep this stuff in mind, if in the future you get any weird electrical faults... 👍
    • that looks identical to the WGNC34 Stagea one I was poking around the other day. Is the other end of that not the ECU plug? If so checking continuity at both ends will tell you which ECU wire it is.  I can start by telling you ECU pin 31 is the top of the large pins on the right in your second pic
    • Bit late....but the one on my stagea has additional holes too, it is for clearance of the bolt heads which hold the radiator latch upright to the radiator support (ie, they are not to locate the panel)
    • My gut feeling was also blowby, it is absolutely crazy when you see how much engines actually breathe when they run a lot of boost or are heavily modified. If you can ever see a motor on a dyno it's pretty crazy, full on steam train action. I thought I was going crazy when filling a 500ml catch can in one 20 minute track session, or maybe two. It's been awhile. But then I saw how much _worse_ it is with harder running engines and I was pretty shocked. In any case I would definitely use more than 1L in 1000miles with that kind of load going through it :p It going nowhere.... is... unusual
