Looks like I'll have to stick the ol thumb out for a ride on a SAU cruise then..... ;)
sau flowing through you, yeeesss (yoda voice) get my liscence back really soon just hang me a pm dude on any events ya wanna be involved in and im happy to help! altho im sure your beast would be welcome as most sa members know of you if not know you. ;)
*edit* just stick a couple sau stickers on it like mattys red tow beast :P
Edited by jenkies
to get more power out of a stock engine would u just need to get forgies?
This is more of a forced induction topic, but the answer is NO
Forgies (forged pistons) will only be a small part to make the engine reliable at higher power figures
(ie you dont need forgies unless you push big power figures and want to keep the moror in 1 piece for more than a year)
i never wanted to put ne stickers on my car (mainly the shopping list!) but i figured the skylinesaustralia one on my lil side windows couldn't hurt. besides, there's too many black skylines around ppl mite mistake me for someone else...
All the more reason to make it look different to the rest of the sheep.......
Can anyone tell me where i can get a f**king manual on females because after tonight i DONT f**king understand their ways at all :cheers: Its like im a magnet to the freak shows of adelaide
I always say that males are like a simple big block V8, easy to understand & always ready to go.............a female is like a complex ferrari engine, close the bonnet and walk away while you still can :cheers:
by chance does anyone hav a PDF form of the Apexi RSM technical and product manual?
I downloaded the english version from the Apexi USA site........but its for the old school RSM
The Japanese site had the right manual, but alas its all in japanese
Trying to logically work out what we did wrong in the wiring yesterday for the speed not to work (worked off a setup map that had 2 versions...........RSM normal or RSM overriding speed cut, we used the latter).
Mind u it felt great to go for a quick squirt in the 31 last nite................the headlights are awesome :cheers:
nah not really steve, thats more for an installation into a lexus :cheers: but cheers anyway
someone was saying the other day that theres a member with a digital copy of it (or access to it)
*edit*
got sent a copy by a mate from 31 club..........he's got a whole heap of manuals like that on CD :cheers:
Edited by Matty 31
    • OK, that is a helpful description, because that sounds exactly like a bleeding issue in the clutch....these are hard to bleed manually even when the damping loop has been removed. I'd suggest bleeding again....start by filling the master cylinder up and opening the bleed nipple. Come back and check every now and then that the master cylinder is not empty. Let it gravity bleed for a few hours and see if that improves
    • I replaced the whole clutch line with the chase bays braided hose, I think it removes that loop, is it the short hose that comes immediately off the slave or is there a drawing in the manual to find what you’re referring to? It was just re-bled when I upgraded to the nismo slave, old slave worked fine but I thought that might help, didn’t change a thing. It’s like the first half of the pedal is pushing air and then when it finally actuates the master the friction zone is tiny. Makes it practically impossible to launch the car
    • Yep, that was one of the things we learned fast in the past with our MX5. When you drive with the top down, you are effectively standing out in the sun, 100% of the time, and not getting in any shade (because roads aren't shaded generally!). Just like standing out in the middle of a field on a sunny 27C day is a bit of a bad plan, so is sitting in a MX5 without sun protection.
    • I also just ordered some Frankenstein bolts and side mounts to fit a hard top Just in case I do find one, basically so it doesn't need to be fixed to the car with only the front latch.......and then gaffa tape to keep it in place for the RTN journey from wherever I get it
    • If your temps are fine now, you probably won't have any issues with where your vents are as they don't look right up at the windscreens high pressure area, so any differences when giving it the beans for extended happy laps would be minimal, but, they should vent heaps when stuck in traffic  Much like how that reverse cowl on my SS let "visible" heat out when stationary, but, because it was basically at the windscreen my coolant temps on the Hwy actually raised because air was being fed into it at speed (110kph), to only come back down to around 90° when I got off the Hwy And your 100% correct about the NC currently not needing vents, but, if I was to add a turbo, and a oil cooler and intercooler in front of the condenserand radiator, and then take it to the track???? It is apparently a recommend requirement if I don't want to worry about coolant or oil temp issues, but, any of the above are possible scenarios, over time As it sits now, with the triple pass radiator and stock air conditioning system, I have absolutely no issues with either temps or air conditioning efficiency, I've been basically daily driving thie car for the last month, both on the Hwy, and peak hour, bumper to bumper traffic, but, that's pretty much expected from basically a standard engine  Talking about no issues daily driving, it was 39° the other day and I was sitting in bumper to bumper traffic on the M5 and then M7, with the top down, and with the air conditioning blowing nice cold air on my feet, balls, and face, well, there was one issue, my head and arms got pretty sun burnt Note to self: leave a hat and sunscreen in the car for such days 🤣
