i broke up with my missus yesterday... and i dont feel too bad atm.
must have been the right thing to do
must be the weather. me and my mrs split last monday, i was ok till i find out she cheated. oh well, more money to pour into the 34 i guess.
It's now official, Freo are the worst team in the AFL!!
How can you be 50 up at 1/2 time then lose the game to a winless Melbourne????
+1 on that
what a bunch of retards. Im not really a footy person but that is almost a joke. How the hell do you lose like that?
Hopefully Essendon can do the same after half time. Although I doubt it. Umpires are being dicks!
yeah couple of bad decisions but wouldn't have affected the score that much
hopefully Port can keep their foot on the pedal
I'm guessing you're a Crow boy???
I'm one of those Alberton ferrals!! :happy:
Yeh, just use the umpires as an excuse. Nar im an Essendon follower, but yeh, don't like port, ex G/F was a port fan.
backed it into the tyre bundles at turn 8 last practice (probably only hit at 30kmh)
it has scraped paint, and cracked the tail light.............thats the bit i was annoyed at myself about as they're expensive (wishing id stayed with S3 lights LOL)...........oh well, nothing a bit of fibreglass cant fix
just makes it look that lil bit more cooner hahaha
yay another essendon supporter! not much to be happy about after this arvos game though. Im gonna cop shit at work tomoro as there is a couple of port fans. I just bought 2 new essendon tops aswell, not wearing them till they win so they might collect dust for a while the way we are going.
I felt the same way you did a couple of weeks ago Luke when we were only just off the bottom of the ladder.
We've had a pretty good run against you guys in the last 5 years.....don't know how long we can keep that up though......wouldn't mind a Lloyd or Lucas in our forward line :P
Yeh i was going to go out and get a few essendon things but might wait til they win also. They dont play that bad, just dont make good use of the football or their oppertunities and if they kicked it alittle more it might get to the forwards alittle quicker.. But yeh a few wins and their back up there.
    • Not really, but the heater box is pretty simple mechanically....if the door is one way the air bypasses the heater core and if it is the other way it goes through it for warm air.  If you are sure the actuator you moved manually is for the heater mix (there would also be one for output air direction) then I'd take the heater box out and see what is happening (you'll have to regass and re-coolant the systems afterwards) BTW pp724 onwards from the GTR workshop manual cover the system in good detail, it is probably worth checking. I think the IAT sensor might be a problem electrically for getting cold (if you got 24 error code not -24 it thinks the incoming air is -50c) and it covers how to test the sensor (although most likely it is either not plugged in or a wire is damaged)
    • Use the GKTech subframe bush and bring your subframe 10mm closer to the chassis. You'll need to fix an exhaust hanger to suit. One of the best mods I've done.
    • You'd really have to pull it apart further to know, it least you can be confident that the one heading to the back is not connected any more. There was once a ground on the shifter seal mount too, your head unit issue could be that simple
    • Perfect, I'll get to it this winter then at the same time as I weld on my anti squat kit.
    • Alright so my 32 only has one temperature no matter what degree you set it to. I’ve tried disconnecting the servo motor arm and moving it either direction and got no change. I’ve fixed the leak in my AC and re charged it and with it on and clutch engaged it still blows hot even though the low pressure pipe going to the firewall is ice cold. Both heater core hoses are hot while running as well. Diagnostic code showed 24 for intake air temperature sensor. Anybody got any ideas?
