i may have gone crazy but im sure we used to be able to edit all of our posts, now it seems i can only change the last 1 i made.
this means im accountable for all i say :) i cant handle that kind of responsibility you know how much crap i talk and how often i offend people and need to change my statements to appear like im a decent human being to anyone that hasnt read them yet :(
is that how it is for everyone now?
was just gonna change my cruise thread to done with pics
Edited by gzilla
ha, ha, too late Dan, you're stuffed now..........just go and swallow a bottle of sleeping pills :)
hahahaha all the more reason to donate once you donate you can even delete your own posts if you think they were that silly :P
>>How to Donate<<
this means im accountable for all i say :down: i cant handle that kind of responsibility you know how much crap i talk and how often i offend people and need to change my statements to appear like im a decent human being to anyone that hasnt read them yet :D
nah, we start at 6am, however we haven't got much on at the moment and with a little bit of persuasion we convinced our boss we weren't needed today. :D
And even then it wasnt much pursuasion LOL..... You heard if we're working tomorrow?
f**k I was bored today.
GET ME A JOB THERE :down:
im so over my boss was meant to do overtime today then he cancels on me because i forgot to put an ingredient in a batch then had to put it in and re-blend then colour didn't come out quiet right, AND then the guy that's been there 15 years couldn't figure out what to put in to fix it and i had to do most the guess work :D
tell me that's worth $16 an hour
hahahaha all the more reason to donate once you donate you can even delete your own posts if you think they were that silly :down:
>>How to Donate<<
Thanks Madaz, was wondering how to donate. I was going to ask... Honest... Considering skylinesaustralia has given me so much, i thought i might give alittle back :D
were u home this arvo?
the keto wasnt there (puddle of oil was tho LOL) but i still knocked on the door..........mandy seemed to kno i was there tho :(
the keto wasnt there (puddle of oil was tho LOL) but i still knocked on the door..........mandy seemed to kno i was there tho :)
What time was this? Picked Dom up from work @ 3, then did some shopping, was home by 4 ish I think.
Dave is right though, should have called me LOL. Ill only not pick it up if I dont want to talk to you :):D
Puddle of oil is from the stupid 4K inverted oil filter dumping it's guts like it had a hot curry LOL. Did an oil change yesterday. Ill grab some H/D Degreaser... no - one will ever know. :(
GET ME A JOB THERE :blush:
im so over my boss was meant to do overtime today then he cancels on me because i forgot to put an ingredient in a batch then had to put it in and re-blend then colour didn't come out quiet right, AND then the guy that's been there 15 years couldn't figure out what to put in to fix it and i had to do most the guess work :whistling:
You only get 16 dollars an hour????? thats crazy.
    • Yes...but look at the numbers. There is a tiny tiny fraction of the number of Joules available, compared to what is used/needed. Just because things are "possible" doesn't make them meaningful.
    • Thanks for taking the time to post that ! If anything changes or happens please do update us.
    • Somehow Vertimass/Oak Ridge National Labs has figured out a catalyst that can convert ethanol into C9-C10 hydrocarbons in basically a single step without ending up with a bunch of ethylene or similar waste products: https://patents.google.com/patent/WO2023224867A1/en I still don't think anything like this will keep us from needing to transition to EVs regardless along with all kinds of other electrification, but things like this will go a long way towards alleviating the problem of how to electrify things like planes. Renewable diesel is seemingly an easier problem as well, Chevron is already running refineries for the stuff and the primary feedstock is tallow and other waste fats from agriculture.
    • Ok so I have sorted everything with my uniclutch and  i can offer up a bit of feedback and some things that might help others.    I found problems with factory damper line. Weird shit and had trouble with peddle adjustment    I used this https://au.gktech.com/products/r33-gts-t-skyline-braided-clutch-line?_pos=2&_sid=22b01b9b9&_ss=r Also when adjusting peddle leave a bit of play. You can get into a over stroke condition easy.. Make sure you can push the slave forward after adjusting to confirm fluid can return to master then you will need to pump it up heaps…..not sure why but that’s how it is.    last thing the splined adapter is machined perfectly. If your input shaft is old like mine was I would put a bit of valve grinding paste on it and stroke it like a 15 year old. Just to give it a tad more clearance and to better match it to the spline.    reason is on a near flat shift I have had situation where the peddle returns a millisecond after you lift from the clutch. No slip or anything but I reckon this is due to tolerance on the spline being way tighter than stock clutch and binding for a sec. I think this will go away but also my spline was old. Box is old so I guess I should have checked better. It’s a super neat fit.    it feels light as and holds awesome without any noise
    • My Fuga Hybrid is JDM, 2014 model but very similar to the V37 from the looks of things..same platform just physically larger and very comfortab;e
