Nick: It's been registered now for 2 weeks today. Overall, LOVE the car! :D I still haven't had a chance to give it a good run (only driven to work and back) BUT I love the 5sp auto - so much nicer to drive to work than the R33 LOL. This morning I had a cop driving next to me for about 10 minutes, he was looking at the car with a very confused look on his face, pretty sure he was trying to work out what it was hehe.
Here's some happy snaps I took in the car park at work:
:D
starting to see quite a few of these around now
looks like yours is missing the part in the middle of the front bar as well.
my mate loves his - been driving it up and down the street with trade plates (doesn't want to go too far in an uninsured car)
Yeh, the front middle is the Tow Hook Cover. Seems that even if they leave japan with them, they often go missing in shipping (as it only clips in). Aparently can get them new in Oz for around $70 IF the mitsubishi parts dealer wants to order it for you from Japan or NZ. Just got to get around to ordering one.
Honestly, don't know for certain yet.. first week was only putting in $20 & $30 here an there. Filled up the tank last Friday, and will see how I go on Monday when I re-fill... hoping it will come out about 12.0-12.5L/100. At the moment its just over 1/2 tank (~25L) for just over 200kms but you can never tell on the gauge, need to fill it up :D
That's in peak hour driving, 27km each way. This is what I used to get in the skyline while behaving myself so expecting the same.
Top right hand corner where it says "options" go in there and make sure "display mode" is set to "Standard"
i run the 9puk extreme HD ceramic 850kg pressure plate
have you tried pressing CTRL-F5
wow doesnt time fly when your having fun :bunny:
thanks for the suggestions.
The ctrl f5 worked, thanks steve ! was getting frustrating just looking at blank white page with half the buttons/emoticon pics loaded and no background :down:
^Due in approximately 8 weeks :down:
BUT we will be putting bubs in a Capsule first, and that will be fixed into the SP23 while brooke is off work. When bubs is big enough for car seats, it will be 1 in the SP, and 1 in the Legnum :bunny:
^Due in approximately 8 weeks :D
BUT we will be putting bubs in a Capsule first, and that will be fixed into the SP23 while brooke is off work. When bubs is big enough for car seats, it will be 1 in the SP, and 1 in the Legnum :huh:
If you want a really nice compact baby seat thats both a capsule and normal car seat look at the Safe and Sound Compaq.
Awesome little seat that fits in the Skyline and fits like a glove in the back seat of the 2007 Mazda 3. :D
Don't bother with the oldschool capsule they are an absolute pain in the arse.
Safe-n-Sound Compaq Deluxe
Converts from rearward-facing (capsule) to forward-facing upright child seat
http://www.productreview.com.au/showitem.php?item_id=33890
http://www.babiesgalore.com.au/view_produc...6categoryid%3D5
The young lad now at 3 still fits fine; quite a tall lad for his age with a size 10 foot. :)
Really don't bother with a capsule they are old, clunky and will do your back in. :)
looks good Lee :)
well i have a newly added speed hole in my front bar :) today @ south rd and regency rd light to turn onto regency was green then went yellow on the guy in front panicked and i went up the back of him :D lucky for me there is very little damage to my car and none to his
    • On the bright side, at least you knew that it happened and remedied before anything happened. A friend of mine just took his Fiat 124 to a shop for an oil change and they didn't tighten the oil filter housing properly. 4.5 quarts spewed out and even after refilling + tightening the cap the engine has a tick now.
    • So, more pain. The FAST manifold is a little larger than the stocker. This is problematic because there really wasn't much clearance to begin with, so going from 'barely enough' well into 'no' is sad based on the external dimensions of the thing, even though where it bolts to the head is the same. Result is the fuel rails sit a good 25mm higher, and this is a bit of an issue with the wiring that runs behind the motor, and the fuel lines, and everything else. When pushing the manifold on, it required a huge amount of force to crush wiring looms to fit it, sensors like the MAP sensor are about 1mm from the firewall, and the FPR just has to bend ABS lines to be forced into place. After some brainstorming and some sad drinking, the loom for some reason ran from the grommet behind the ABS sensor, then to the driver side head, then back to the passenger side head. So all of this was pulled back and stripped, a few wires cut and rejoined, so that the 'branch' was now on the passenger side's head as below: Before you basically couldn't see anything behind the driver head. This is much improved! The MAP sensor is now pointing up (instead of at the firewall) Brackets have been made up for the rail. The rails are for a LS1, the manifold is designed around a LS2 as it's base. Which of course has slightly different bracketry and water pump clearance, hence the mods people need to do. Should be hopefully mounted tonight. I spent money on a new FPR that is slightly more compact than my Turbosmart FPR1200. The gauge has also been moved to the rail. There's also apparently an ORB to AN Union instead of the adapter, because the ~25mm of the current adapter is going to make the difference. Provided this all goes together and arrives today, it'll be the totally not stressful attempt to start it.
    • This seems like a pointless exercise. There is no E30 availability. Ongoing availability of E85 should not be assumed. Flex-fuel is the only sensible approach, so you can use E85 when and where you can get it, 98 when that's al you can get, and anything in between as you fill it up and drain it down. And if that means replacing the pumps, fitting a flex capable sensor/ECU/whatever has to be done to these Renault shitboxen, then.....so be it?
    • Sorry, I wasn't very clear.....just that the standard injectors are apparently good over 600rwhp/450rwkw which you won't get to on standard turbos anyway.....they are much better sized from factory than we are used to in RBs.
