The Sa Wasteland
Cubes
 Share
Lol i pay out most female drivers, cos seriously so many of them cant drive for shit! Love the ones doing their make up etc as they drive.
Yes im paying out my own 'kind' here but most of them are just baaaaaad drivers.
I know how to drive :whistling:
I just hate relying on others, like the freedom of having my own car
I know how to drive :nyaanyaa:
And having the BF drive it for you! :whistling:
I haven't driven mine for 2 months.. :P
Laid up in the drive with with bits off waiting for some other bigger lumpier bits. :D
n/a sucks I really miss the mid and top end rush.
You know its been too long when a VN commodore and Mazda 3 starts to feel like its got some punch.
no need to miss boost buy a little turbo charade :P with a few mods they can run 14 down the quarter mile
haha true that.. u got me there :P
I should say i miss boost :) Gonna Miss it more when the car sells!! :(
Iv been in charade turbo and bloody hell they go alright also im a fan of the tx3 and et pulser both very zippy cars :P
Had a ET back in the day, ran 7psi low boost and 14psi high boost, I bet you know which was run the most......... Went thru 3 gearbox's, they are shite!! The Tx3's arent too bad, but always remember Jr who used to work at ET back back in the day with Marky, he had one and shat the box out also, unless you put a 4G Evo motor in them, then they rocket, was a black one out at Mallala the other week............
Apparently that black tx3 has full evo running gear
Actually your right, now i remember........
my pfc for sale! look in SA fs section!
WTF, what happened with the AFM situation?? Other people are running 32 GTR PFC's on their cars........
Hi flick lol im one of those girls that puts on makeup when driving lol
and i just brought the best cup cakes they are just like sprinkles cup cakes in america so yummy :)
haha bunny, well ill forgive u :)
So just got my car back from the mechanics after a week and wow feels like a dream to drive! So much better! There isnt one hose under the bonnet that wasnt replaced.. few new pipes (cant remember exactly which ones) cos they were corroded. New thermostat.. cooling system completely flushed, cleaned and refilled. Engine bay and all underneath professionally cleaned and all shiny!
Shame to sell it now lol
 Share
    • Another thought, are those actually NEO cams made for the NEO head (shim over bucket) and not the non NEO head (hydraulic lifters)?
    • This is the first time I've checked my fuel pressure and I've got no idea what the pressure was before this. So I'm not sure if this is 100% the true cause of my idling problems atm, but this high pressure is my first clue to something that is "out of spec" according to the workshop manual. Also, you can see in the video, the haltech tries to get the afr target and it does maintain it at 14.2. So I would assume the afr is fine? I have to dissagree with the cluster comment. I don't think it's a bad solder joint. There's nothing wrong with my Nismo cluster because I swapped out the cluster to my old nissan one and it does the same rpm glitchy thing. So to me, thats the signal coming from the ecu that is farked. I bet if i were to put both those clusters in a working r34 gtt, it would work as it should.    I just took this video now to show what happens to the fuel pressure when I remove the vac lines on both the FPR and damper. It remains at 50psi:   Can definitly feel theres vacuum. No aftermarket reg, just stock one. I reckon its the signal coming from the ecu. So correct me if im wrong, cas send signal to ecu to show rpm of engine (and thats what we see on the haltech software) then ecu sends out ignition and injector pulses ect ect, and then spits out a signal for the rpm gauge on the cluster? Makes me wonder if something in the injectors electrically (solenoids?) or something is causing some weird feedback to the cluster signal.  Yes! They did. And I also think they are related/connected to this idle issue.  Haha sorry about it. I just filmed it with my phone. Let me know if you want me to get something els specific on vid. Yeah it's really odd. I would like to try and diagnose the injector wiring next. Don't know if that requires an oscilloscope?
    • Hi Bud, Yeah that's the next step, going to get these checked. they were set "bang on" when it was built and its always been present. They may well be wrong though!
    • @Toff if it's a NEO and it's making the noises you're describing, it sounds like you need to work on the valve clearances and measure/replace shims as required.
    • Thread revival, apologies! I have a similar issue, strange noise that appears shortly after starting the car, fluctuates a bit with RPM... If you bring the revs up the noise sort of follows / trails behind and then settles if that makes sense? Engine was built years ago with CAMTECH 268 Cams (9mm lift i believe) and the rest of the upgrade kit with the springs and retainers. Can you upgrade the pulley itself, if the spring is too weak (same as on the VG30 Lumps) or is it pointing towards another issue?   Cheers!
