Well done on the rims! Got a phone call from my missus this morning, some bitch decided to cut into her lane, she swirved to not get hit and ended up getting some gutter rash on my BuddyClub QF's :blush:
Not terrible but bad enough, looks like they will have to go in to get the lip re-done but nothing major
dunno Adrian - cant be that hard though we can take a look one day
Spewn Craig - have you tried taking the dash apart and seeing if wiggling it will fix it? -
sigh Luke /hatesFPD
na, will have a look over the weekend...might just buy a set of white, kinda over the blue.
good thing is, i can do it myself this time
HELP: running stock suspension and to my knowledge stock diff and so on and so forth. Yes my hicas are still connected and im getting a lock bar but im thinking diff's on its way out. How do u tell???? I just took of at lights sensibly of course and it shuttered that hard it knocked it out of gear!
Help Please I offer hugs and kisses
lol no offence ladies but sometimes your more trouble than your worth :rofl:
my car never complains we've been out too long :) or aren't you going to wash me in the morning
you can plat there hair :)
will agree to, friends with benefits FTW
    • Yeah - My key still does the chime thing. I followed the procedure but it didn't activate on the (identical) third set of keyfob that I had. I vaguely remember the alarm saying you can only pair two keys with it. Now that I've dug it up, it appears that you very much can pair keyfobs to the alarm system. (which are the fobs I use to unlock the car). I have successfully diverted the thread and can probably not use the OEM keyfob ever again unless I use the aftermarket alarm and attempt to pair the OEM keyfob to it. Which might just work, or not :D. I definitely used the nissan method and not the aftermarket alarm method.
    • What makes it worse is that Nissan made keys in the same style, for example R34 and Stagea, but they work at different frequencies or something like that. So they look the same but the remotes are not interchangeable. I learned that from some guy selling aftermarket blank keys.
    • Does your door chime work when you have the key in the lock and open the door? I've had that disabled because it's f**king annoying and it is one thing that messes with the pairing. Because now the car doesn't detect key in ignition anymore and the slide-key-in-and-out sequence does not trigger the pairing mode anymore. The service manual has a section on the various bits involved in doing the syncing. I presume it'll be similar between Stagea and R34.
    • Agree, but meh, I think is is based more on LOLS than actually apples to apples, like, who would have thunk a turbo 4 cylinder would not beat a NA 4 cylinder  I think with just basic N/A mods, like a exhaust and tune, it would be equal to the Mini in its current form, maybe I know my current 2.5 would "chop the mini" as the midrange now has a night and day difference in power delivery compared to the tuned 2.0, by around 20kwatw and 30nm from around 2k rpm "ish"....... I'm kinda hoping that they do a N/A build, either with the MZR 2.0 or with whatever they decide to use If I recall correctly they did talk about K swapping one a while ago
    • Can't see that being a thing.
