The Sa Wasteland
Cubes
 Share
Be carefull when swishing the fuel around in the cooler.. First time I did it I sprayed myself as when you swish it evaporates and creates pressure then sprays out from your hands holding the ends. :S
hey guys after a bit of help. my car is missing under boost when on more than 9 psi. i tihnk eithermy fuel pump needs an upgrade or my sparkplugs are fouled..... got half the day off tafe tomorrow so gonna check the sparkplugs first.... check their quality and age. just wondering where would be a good place to get spark plugs and at a good price?? ive also heard more expensive isnt always better for rb's? as they dont last aslong?? also how do sparkplugs usually last kms wise??
many thanks for your help in advance... not putting up a thread about it cos there is no point.
Also check your cooler pipes......
Irridium plugs are around the $120 mark!!
getting there sbout 45 mins on it tonight
alot of time is wasted looking @ tuts reading then trying then undo'ing when it fails re-reading redoing re-undoing you may notice i chopped up another picture and overlayed it in there and thats where the red on the rear shot has come from
Mark - also check the gap alot of plugs are sold @ 1.1mm and should be .7-.8 for high boost
at 1.1mm they may run ok but up the boost and run crap
i heard irridium dont last long? and 120 each... yowza!
thanks steve yeah ill gap them and check them out. got hks sparkplugs in the vl.. might just swap depending on condition
no, 120 the set, Simon32 says just get copper there fine you just may need to replace them sooner
iridiums are meant to last longer thats why there dearer oh and there made of iridium i guess
Reuben your Air box is that basically what the R33 one looks like ?
I believe so! I've got a HKS pod under it. Its only there to appear stock ... so is the rest of the work to the bay. Got to keep it looking stock as a bone :)
I'm also replacing my plugs and ensuring the gap is 0.8mm.
Mmmmm ... coilpacks :D
Ahhhh i thought that was what you were up to!!!
 Share
    • Great write up. I was thinking abt getting the niftycity for my g37 the aliexpress links u shared r not working anymore. Can u share again please?
    • Good turnout and some old faces.
    • Wow its been a while since Ive signed in for sure.  Time gets away... Good question. So much was different between the two designs.  The RB315 was a test to see if I could do it.  Limitations were for the most part due to local machining capability.  Tolerances were an issue.  The 3.15 used a single OD dry sleeve, and was almost the same as a kakimoto spacer plate engine, except I used a plate design similar to the OS Giken plate.  I did not make the top flanges thick enough either.  I can't be sure if it was machining tolerances, or thermal distortion of the sleeves, but the engine did produce quite a bit of blow by.  The modified 87mm RB30 crank was also an issue, and was no where near as nicely balanced as the forged 90mm crank in the 3.4. The 34 was a next level build.  The sleeves were stepped for max thickness, and were a semi-wet design breaking though into coolant completely in the block.  Minimum thickness was 3.75mm and max was 5mm with the 90mm bore, and the new spacer plate also fully supported the tops of the sleeves closed deck style.  This combined with far superior CNC machining, and a cylinder hone finish that the machinist does on 3000hp pro stock cars resulted in no noticeable blow by at all.   In the end the 3.15 was removed to swap in the 3.4.  I discovered the modified RB30 crank had partially sheared the woodruff key on the balancer.  That was all that was wrong with it, but it did make the engine a paperweight at that stage. $1100 to make another crank for an engine with blow by issues was not worth it, considering I'd started playing with all Nitto forged internals instead. I hope you found this interesting.   Cheers, Ian
    • All their parts, when order directly off them are made to order. So you're able to customise fitment of things or delete things. E.g. I asked for no throttle cable bracket, no IACV port, etc. on my plenum. In hindsight, I should have asked for an IAT port/fitting welded on, hindsight no. Should have bought a M2 or 3 lol.
