yeah im thinking i want to do the same
anyone have a R33 stock air box would like to swap for pod filter
PM me will put up in the wanted section later
I believe so! I've got a HKS pod under it. Its only there to appear stock ... so is the rest of the work to the bay. Got to keep it looking stock as a bone :)
I'm also replacing my plugs and ensuring the gap is 0.8mm.
Mmmmm ... coilpacks :D
With coppers. Best/cheapest place to grab them is Motor Traders at around $2.85 per plug. Else where pay the usual $4.40 per plug. Which really isn't that much anyway.
RB20/25/26
BCPR6E for stock power to around 250-300rwkw. 0.8mm pregapped.
BKR7E-11 for powers 250rwkw+. 1.1mm pregapped need to gap down to 0.6-0.8mm depending on boost.
The two above plugs are the v-groove type.
I find they last a good 20,000km's. By 30,000km's they are beginning to look quite rounded. :)
I run the BKR7E's have absolutely no issues with fouling. At 268rwkw the BCPR6E's were coming out a looking a little hot, the BKR7E's heat range is spot on and look nicely tanned.
If you have issues with fouling the car is running way too rich and really should be sorted.
doing some window shopping :)
http://www.j-spec.com.au/list/index.php?ID=13050
http://www.j-spec.com.au/list/index.php?ID=12821
one needs a bit of an engine bay clean up but is cheap!
Edited by Damo_R34
ok i took my coilpack cover off....
started the car waited 20mins or so to hit full operating temp...
nothing...
so i drove it and still NOTHING
so i have come to the conclusion that it may be getting hot under the cover at full opp temp?
i guess i drive it with the cover off till my spitfires arrive.. is it ok to leave the cover off??
and i correct in saying that this was prob the problem?
cheers
no, 120 the set, Simon32 says just get copper there fine you just may need to replace them sooner
iridiums are meant to last longer thats why there dearer oh and there made of iridium i guess
blow me down! i just ripped one out and its ngk irridum.. looks fairly clean and its gapped to 1.0 or something, will close them all down to 0.7 and see how i go.
    • Apexi, though I'm not comfortable with setting the idle, knowing me I'll f**k it up lol.
    • What ECU is on your car @silviaz? You can just change the idle target table yourself and the IACV duty cycle. Noting that if you play around with the screw you'll also need to revisit the idle base duty table as you will end up offsetting the lot. Another reason why DBW is superior, there's less mucking about.
    • Yep. Saw that on the image above but, wonder if it makes more sense to clean out the iacv because let's say in theory mine is dirty and if I clean it the rpm will drop. If I first go to my tuner to drop the rpm and then go to clean my iacv won't it drop further or is the rpm a fixed number?
    • Yeah it was a good result, and confirming the car is full of fluids and all interior etc in, other than fuel. I think a few pages back (maybe many pages!) he mentioned some serious lightening in the doors with the chassis punch, might have been done elsewhere I hadn't seen yet too
    • He still had the suspension dialled in for him! I would have sworn the lowest weight he ever got to was 1300kg though Maybe Neil had been drilling a LOT of holes somewhere you haven't found yet... 😛 Or has he also drained all the gearbox and diff oil out too, between it, and a tank full of fuel there's about 65kg to 70kg to add back in I'd guess. 😛
