The Sa Wasteland
Cubes
 Share
I herd that a new law is comming in so you can run 19s or 20s on a skyline so will this mean the clearance from center of the wheel to guard will change??????
Its always been 2 inches above what came on the car stock. So for a '32 gtr, max is 18", for a 33 gtr, 19" for a '34 gtr, 20".... whether or not the tyre/rim is suitable for your setup, I guess that depends on the car in question but from what I understand, the 18" is the most I can put on my GTR. Which suits me fine cause I think the r34 gtr rims are pimp. So if any of u guys with 34gtrs get 20's, I'll take yr old rims >:(
-D
yeah it surprising hoew easy it is once you know how, i still gotta pull mine apart ans see why one has stopped working.
meh, ill add it to the 50 other things to do.
Edited by craig R33
craig... 3 more posts!! so 2 after replying to this!! haha
i even found out y my rear wiper wasnt working... last guys to fix my light switch forgot to connect it hahaha
ok thanks for the advise all. gapped them all to 6.5 and its nevver run so strong on high boost. fixed the problem completely!
went up anstied hill and this was the result: :(
ha ha, someone just offered me 600 for my rims my reply was.......ROFLMO.......thats all i wrote.
god, next they will want them for free.
Yeah, everyone wants something for nothing!
I had some the sphincter of the universe offer me $500 for my GSXR race bike which I'm selling for $5000 (bargain as is). I simply replied: "Come back when mommy raises your allowance."
Tell him "Sure, I'm desperate. I'll take the $630." Then give him an address of a biker club. :(
Thats a popular response of mine too. They won't be so scabby next time.
ok i took my coilpack cover off....
started the car waited 20mins or so to hit full operating temp...
nothing...
so i drove it and still NOTHING
so i have come to the conclusion that it may be getting hot under the cover at full opp temp?
i guess i drive it with the cover off till my spitfires arrive.. is it ok to leave the cover off??
and i correct in saying that this was prob the problem?
cheers
i ran it like this on the street for 2 years (and still do on track)
its not a problem, just dont go high pressure spraying your engine bay
HELP: running stock suspension and to my knowledge stock diff and so on and so forth. Yes my hicas are still connected and im getting a lock bar but im thinking diff's on its way out. How do u tell???? I just took of at lights sensibly of course and it shuttered that hard it knocked it out of gear!
Help Please I offer hugs and kisses
Some1 any1???
 Share
    • Great write up. I was thinking abt getting the niftycity for my g37 the aliexpress links u shared r not working anymore. Can u share again please?
    • Good turnout and some old faces.
    • Wow its been a while since Ive signed in for sure.  Time gets away... Good question. So much was different between the two designs.  The RB315 was a test to see if I could do it.  Limitations were for the most part due to local machining capability.  Tolerances were an issue.  The 3.15 used a single OD dry sleeve, and was almost the same as a kakimoto spacer plate engine, except I used a plate design similar to the OS Giken plate.  I did not make the top flanges thick enough either.  I can't be sure if it was machining tolerances, or thermal distortion of the sleeves, but the engine did produce quite a bit of blow by.  The modified 87mm RB30 crank was also an issue, and was no where near as nicely balanced as the forged 90mm crank in the 3.4. The 34 was a next level build.  The sleeves were stepped for max thickness, and were a semi-wet design breaking though into coolant completely in the block.  Minimum thickness was 3.75mm and max was 5mm with the 90mm bore, and the new spacer plate also fully supported the tops of the sleeves closed deck style.  This combined with far superior CNC machining, and a cylinder hone finish that the machinist does on 3000hp pro stock cars resulted in no noticeable blow by at all.   In the end the 3.15 was removed to swap in the 3.4.  I discovered the modified RB30 crank had partially sheared the woodruff key on the balancer.  That was all that was wrong with it, but it did make the engine a paperweight at that stage. $1100 to make another crank for an engine with blow by issues was not worth it, considering I'd started playing with all Nitto forged internals instead. I hope you found this interesting.   Cheers, Ian
    • All their parts, when order directly off them are made to order. So you're able to customise fitment of things or delete things. E.g. I asked for no throttle cable bracket, no IACV port, etc. on my plenum. In hindsight, I should have asked for an IAT port/fitting welded on, hindsight no. Should have bought a M2 or 3 lol.
