hehe, you wanna know how i pissed my ex off???
i posted her little buzzy friend to her house, addressed to her dad, with a photo enclosed.....
see, i was smart at some stage...
Oh Craig, that is some of man's best work right there. How bad was the picture, and can you post it up. :)
how do i find out if my timing belt has already been replaced??
i have owned it since 116 k, and my mate who had it before me bought it at 109k..so he doesnt even know if it was done...
i donrt really wanna spend the money on a new one if its only 17 thousand ks old!
i could spend it somethin else, like new brakes....
+1 on above comment
For rb20 and rb25 timing belts please contact me, I have done countless amounts on both motors, Did mine recently even tho its only done 80k.... lol and yes i'd change water pump at the same time! genuine parts aswell.
adrian, scott got those lock bars yet?
Edited by Ryanrb25
i can get trade discount through nisscare...Belt around 70 bux, generic Pump about 50 bux, genuine pump is around 140-160. My labour dunno, but not 300+ like everyone else. plus coolant about 10 bux, gasket glue ill supply lol
PLUS, ill show ya how to do it while talking some shit at the same time. :)
Edited by Ryanrb25
    • I appreciate the detailed explanation, think I understand now. I spent the better part of last night reading what I could about shuffle and potential solutions. I had replaced the OEM twin turbo pipe with an alternate Y pipe that is separated further away from the turbo. The current one is from HKS and I had a previous pipe that was separated even further away, both have shuffle. I had heard that a divider can be welded in to the OEM pipe to remove turbulence, and figure that aftermarket pipes that are more separated would achieve the same thing. From what I read, most people with -10 turbos get shuffle due to their size, though it's a bit less common with -5s on a standard RB26. I think Nismoid mentioned somewhere it's because OEM recirculation piping is common in Australia with -5 cars. It seems that the recommendation tends to vary between a few options, which I've ordered in what I think is most feasible for me:  1. Retune the MAP or boost controller to try to eliminate shuffle 2. Install OEM recirculation piping 3. Something called a 'balance pipe' welded onto the exhaust manifolds. I don't know if kits for this are available, seems like pure fabrication work 4. simply go single turbo My current layout is as follows: Garrett 2860 -5s HKS Racing Suction intake MAF delete pipes HKS racing chamber intake piping hard intercooler piping,  ARC intercooler HKS SSQV BOV and pipe Haltech 2500 elite ECU and boost solenoid/controller HPI dump pipes OEM exhaust manifolds HKS VCAM step 1 and supporting head modifications Built 2.6 bottom end All OEM recirculation piping was removed, relevant areas sealed off I'll keep an eye out for any alternative solutions but can get started with this.  Only other question is, does shuffle harm the turbo (or anything else)? It seems like some people say your turbo shafts will explode because of the opposing forces after a while and others say they just live with it and adjust their pedal foot accordingly.
    • That worked out PERFECTLY! Thank you big time to JJ. He was able to swap me his stock diff. He drove all the way to me as well. Killer! Removal & install was pretty straightforward. The diff itself is HEAVY. So that’s a 2 man job.  Man does the car drive nice now! Couldn’t have worked out any better 👌
    • I'm interested,do you still have it?
