Very productive day again today! Water pump, belts, coilovers, coilpacks, and more importantly, MY COOLER! The fan hits the crossover pipe and ticks like a clock on speed, we didnt have enough time or tools to properly cut all the shit out of the front bar, so it sits 2cm forward and relies on 5 cable ties for support, but i love it.
Yeah we are going to finish it all off next weekend, i dont drive it during the week anyway so it will be fine until then. Kellie earthed my boost solenoid too, couple more pounds, pulls so much harder through 2nd and 3rd now!
hey damien, did you earth it via a switch or did you just earth it so its constant?
interested in doing this boost solenoid trick
was the difference noticeable?
Hey Pete,
My mate had one in his s15. Setting them up takes awhile but once all set they work like a dream.
Other option i would be looking at would be a profec B.
Thanks for the reply Luke.....I already bought it cause I was told it was the best on the market (definitely the dearest).
I didn't realize there were so many features to setup......I suppose your mate set it up himself so at some stage I'll sit down with the instructions & have a go.
On the matter of belts, waterpump & gears, we may have to have a chat about your rates sometime Ryan.......I've got a workshop full of gear but no time to scratch myself lately.
someone sell me there rb25det series 2 engine pack for like real cheap :)
Ha. I could sell you one, but it comes with a Stagea. Not cheap ;)
I WANT RB25!! had my first drive in one today! so jelous!
Hmm, I recall you and Min came for a spin in the Stagea not long ago! :D
:D
Anyone know the name and number of the shop on henley beach road that sells work safty gear? Iv been searching for it but i cant remeber he name of the place, i need new work clothes and boots
I reckon you're talking about 'Yakka Aust Menswear' corner of Henley Beach Rd & Clifford St, Torrensville.
Also try 'Aust Safety Specialists' 16a Ashwin Pde, Torrensvile (just up the end of Clifford Street)
I'll ask my brother about it, cause im sure he wired it all up. he might be willing to help wire yours up or give you some info. I'll ask him and let you know.
edit: spoke to my brother about it. Wiring it up isnt that hard its just setting it up. You basically have to do street driving to get it set up correctly. Its awesome for holding boost, whatever level you set it at it will hold it, but when it comes time to up it more it can be a pain. If you want it at one level i would suggest leaving it at that.
Edited by Luke_ENR34
I've got it all wired up Luke but it just needs all the parameters set up properly otherwise a setting for 10psi can boost as high as 18psi if not configured correctly
    • He made that comment in my thread - In my case the vents ARE to lower engine heat, when the car is not moving, which is the only scenario I have heat problems with the aircon on, sitting in traffic, on 40C+ days. I can't imagine a scenario that this NC needs any at this point in time. I do not know if it will actually make my cooling when the car is MOVING worse, and I sincerely hope that won't be the case. If it does, well, um, f**k.
    • Nice, thanks. Thats why I was asking, there'd been a fair bit of discussion in the E90 world about vents and where it makes sense to put one (ie, over the filters is not great as that is inline or slightly behind the struts and in higher pressure area). I struggle with air flow and pressures. It sill weirds me out that a radiator in the boot can work.
    • Neither really Vents, when located in the right place, will lower the engine bay "pressure", as air has a path to escape, thus lowering the engine bay pressure, thus.....improving the efficiency on the coolant stack (read: IC, condenser, radiator) This is why the Blits vented bonnet on my 33 worked so well, the vent was in the front 1/3 of the bonnet, which put it right after the radiator  If the vents are to far back toward the windscreen, which is a high pressure zone, it can actually force air into the engine bay, causing higher pressure and effectively loosing efficiency on the cooling stack, like the fab of raising the rear of the bonnet, which does allow heat to escape, but only when the car isn't moving  There's heaps of cool "fluid dynamics" info out there, but, I'll attach a video of a 'Merican joint that focuses on "Miatas" as I found it when looking into vents for mine, they explain it way better than me
    • Poor bleeding. That stupid damping loop in the plumbing that should be completely replaced with a braided hose. Just the first 2 that come to mind.
    • Forgive the potentially silly question but are the vents for bay temps? I've been toying with how to reduce my bay temps because man, it gets HOT in there and a small subtle vent somewhere I think might help. Or, maybe they're to assist with just the intake temps?
