Nice... 250rwkw odd is definitely a lot of fun. :whistling:
I'm in the process of dropping a set of cams 265/265 9mm in to mine at the moment then off to boostworx for another tune with a tad more boost. I'll keep cranking boost in to it until it stops making power. :D
Fingers crossed I can crack 300rwkw on the std exhaust manifold.
Last time I was on the dyno it made ~260-268rwkw on 1bar with std cams; hopefully I see 25-30rwkw increase with the cams on the same boost.
how much hp left in that turbo Darren and is 17 psi still safe on standard head gasket or has he gone for reliability and safe tune, was that a slide high flow
ahhhhh not sure hp wise, but id say it might have about another 20 more killa wasps in it, if he's only on 16psi then in sure it could boost upto 18 easy and be up around the 260-270, but then yeh the turbo will be maxin!!
Nah its a ATS Hiflow and yeh still on standard head gasket!!
Anyone had a day at work that just did your head in?
This bloke had one of those day's;
What a f**king looney! :laughing-smiley-014:
Felt sorry for the female co-worker who copped the monitor in her face. :D
Everyone must not like working there, if they were happy to stand around and let him trash the place.
Hope your mum is feeling better now, look after her good we only get one
Nah Steve, mother has epilepsy and she had a bad night last night with a few fits during the night, as a result, I got 9/10ths of bugger all sleep
i was sick mon tue with the ful or something, got to work yesterday still sick as and got reemed for having 2 days off even tho i had sick cert from dr and told him i was that sick i couldnt even get out of bed to take locky to school and that chad came over with some dinner for me. :D
Then today i get a email BC to me this morning saying he wont be in as his son is sick and his wife is at work night shift and his son cant go to day care, his son goes to his aunty's not day care
seriously WTF is anyone a boss on here what do you think :D
    • Apologies, while id like to put the MAF as close to the TB and relocate the recirc, this may be too much work. Will most likely end up just putting it on the original AFM spot ( onto/next to the airbox ).  Was going through nistune, found a pretty nifty doc on this. Nistune MAF Notes. Also, i was looking through the bay, and there seems to be a tube/line connected from the A/C to the intercooler piping ( Between the smic and the recirc), what does this do as the crossover fmic piping doesnt have any connection? plumbing? not sure what you call it but the nipple thing ahah.  Also, been reading up more about crossover fmic in regards to the legality of having the hole drilled for the piping, this would most likely need to be engineered right?
    • My advice is if you need a big build done do it in Japan. The yen rate is so favorable and there are shops that can be genuinely trusted and not micromanaged/carefully monitored every step of the way. Garage Yoshida is obviously my preferred option but they're so busy these days and all interaction with new customers has to be mediated through BBL/Toprank now.
    • I haven't....but a poorly made one would terrify me. Surely a good second hand one is the go, as they don't work hard and no-one wants to keep one after they are finished with it A big consideration would be the weight of the shell you are putting on it....is it a fully dressed chassis or just the body
    • Not stock. All remade. Mostly looks stock because the pipes run to and from the standard holes in the inner guard to get to the return flow FMIC. I'm not sure which question you're trying to ask, because it seems like "stock position" vs "stock position".
    • Hey, it's a GT-R, it's just as significant a moment as mine😁 It's not ideal when things are uncertain; I'm the type of person that always has a set plan for things in life so being unsure of this plan puts me in a weird place mentally.
