Yeah man still got original injectors in there and still have to get remap from jeff from turbo tune. That was running at 12 psi but as adrian said I'll wind it up to 14 pound for the next dyno run and while he does the remap so i feel a little safer. I was just curious what i was running so i got a printout.
sounds good scott......just be carefull if you're planning on running 1bar boost on ceramic wheels......it's not the the turbo dying that you have to worry about but the bits they may find their way into the combustion chambers :thumbsup:
SLED,
Its only the 26's that have the issues with sucking ceramic back in to the motor. :banana:
Providing EGT's are kept in check with a good tune and no track days 14psi is all good on the stocker rb20 turbo.
There will be bugger all increase in peak power going from 12-14psi; its the mid range that will sit up and feel alive; transform the whole car in comparison. :thumbsup:
very impressed with my car through the hills last night, Stayed in forth 90% of the time with fantastic low down pick up, Pulls like a f*kn freight train considering the shitty tune. Very loose in the arse end. Ii want a GTR! I used about 30 litres of fuel in about an hour LOL! Once again, EBC greenstuff are fantastic.
Edited by Ryanrb25
I hear ya Ryan.....mine wasn't too bad in that department when I did the hills run with my mates 4WD Porsche & Maserati but I double hear ya on the fuel issue!!
yea flat 10.2:1 AFR's arent good for economy.
Was considering putting 3540 on the 25 to crack some big numbers but response like 14psi at 2000rpm is great for those exits.
adrian, sorry to lead you in the wrong direction on the way home hahahaha...lucky i realised when i did!
Edited by Ryanrb25
ahhh ok....I thought they had ceramic wheels too
They do :thumbsup:
For what ever reason the RB26's suck the ceramic back in to the motor where as the single turbo's never do. Most likely a little to do with manifold design and possibly cams.
At 2k? :banana: Thats better than mine; got dyno sheet?
Mine makes an 1psi off idle; by 2000rpm its around 4psi, 2500rpm 8psi and 3000rpm 19+psi.
?? did you come across police
who got defected tonight on our hills run??
wasnt luke was it? hmmm...
they are but they dont get sucked in the motor Joel is saying
They do :thumbsup:
thats wierd isn't it....I wonder if that's more the exception than the rule....what happens to the bits when they do fly apart then?
One theory could be that due to the cam overlap the bits make their way through the inlet then straight out of the exh valve before the bits get combusted.....poor cats if that is the case!
Just to clear up, Dan (Inline_6) got pulled over at the end of our cruise last night, but the cop just pulled a skyline over for the hell of it coz her boyfriend is on SAU! No defects, no inspection. Was a good night tho, i DEFINATELY need some better light globes, just cant see sweet FA without highbeams.
    • Among other things yes. Making sure to either use an oil pressure regulator or the right restrictor size for your oil pump/range of oil viscosities you intend to run, making sure you plumb the lines correctly, turbo should be placed such that it siphons properly even when the water pump isn't turning so you don't boil coolant in the turbo after shutdown, oil return should be low resistance and also preferably picking the one that is most likely to return to the pickup as opposed to some other irrelevant part of the pan. It's far from impossible to figure this out but I have seen people really, really struggle and if that's the case it's easier to just take the path of least resistance. To me, bolt-on twin turbos are a fixed cost whereas single turbo is almost unbounded.
    • Latest round of updates on the car. I purchased and installed a SWS clutch slipper to help with 60ft times and got some second-hand good condition 275/40R17 Hoosier DR2 radials. Test and tune in November showed the tyres were an upgrade over my over 15 year old mickey Thompson's and I got a 1.8 second 60ft and pb et of 11.71 but even then, that run wasn't great due to rain and driver error (the event got called off 10 minutes later fast forward to the weekend just gone 25th of Jan and there was finally a break in the weather to let racing happen. The first run the track was slippery and only managed a 12.1@129 Second run the track was better and got a new pb et and mph: 11.54@131   Lith and I then worked out that I installed the previously mentioned clutch slipper incorrectly and its never been working, and I had just been dumping the clutch the entire time, we also noticed it was on street boost and not race boost. So I lined up for a third run with the car turned up in the first two gears, but the passengers side axle objected to clutch dumps and left the chat which stopped my weekend.   so there will be another attempt in the future once I replace the tyres as they rubbed and are stuffed now. but a low 11 should be on the cards.
    • Ceramic coating and heat shielding, you mean?
    • Turbos don't require pulling the motor apart so that's "easier". I would recommend the Nismo R3 turbos instead if you want to do stock twin turbo. It doesn't make as much power as the 2530s but it's only like ~50 whp off the mark and should have better response (ball bearing CHRA, slightly smaller turbo). A local that went with a Garrett G30 and 6boost manifold recently nearly burned his car to the ground after the hood insulator started melting and and burning so if you go single turbo I recommend doing a lot of research and validation work to make sure you don't do the same.
    • New rear lights, filler panel sprayed, cleaned and back together    before, during, after shots 😍
