The Sa Wasteland
Cubes
 Share
I'm bored now!
Went riding with 'the lads' thru the hills, talked shit, had vilis and rode home ...
I've had some scotch, but I'm bored. :D
Might download some porn :)
Yeah man still got original injectors in there and still have to get remap from jeff from turbo tune. That was running at 12 psi but as adrian said I'll wind it up to 14 pound for the next dyno run and while he does the remap so i feel a little safer. I was just curious what i was running so i got a printout.
sounds good scott......just be carefull if you're planning on running 1bar boost on ceramic wheels......it's not the the turbo dying that you have to worry about but the bits they may find their way into the combustion chambers :thumbsup:
SLED,
Its only the 26's that have the issues with sucking ceramic back in to the motor. :banana:
Providing EGT's are kept in check with a good tune and no track days 14psi is all good on the stocker rb20 turbo.
There will be bugger all increase in peak power going from 12-14psi; its the mid range that will sit up and feel alive; transform the whole car in comparison. :thumbsup:
very impressed with my car through the hills last night, Stayed in forth 90% of the time with fantastic low down pick up, Pulls like a f*kn freight train considering the shitty tune. Very loose in the arse end. Ii want a GTR! I used about 30 litres of fuel in about an hour LOL! Once again, EBC greenstuff are fantastic.
Edited by Ryanrb25
I hear ya Ryan.....mine wasn't too bad in that department when I did the hills run with my mates 4WD Porsche & Maserati but I double hear ya on the fuel issue!!
yea flat 10.2:1 AFR's arent good for economy.
Was considering putting 3540 on the 25 to crack some big numbers but response like 14psi at 2000rpm is great for those exits.
adrian, sorry to lead you in the wrong direction on the way home hahahaha...lucky i realised when i did!
Edited by Ryanrb25
ahhh ok....I thought they had ceramic wheels too
They do :thumbsup:
For what ever reason the RB26's suck the ceramic back in to the motor where as the single turbo's never do. Most likely a little to do with manifold design and possibly cams.
At 2k? :banana: Thats better than mine; got dyno sheet?
Mine makes an 1psi off idle; by 2000rpm its around 4psi, 2500rpm 8psi and 3000rpm 19+psi.
?? did you come across police
who got defected tonight on our hills run??
wasnt luke was it? hmmm...
they are but they dont get sucked in the motor Joel is saying
thats impressive cubes..
Getting my car tuned on tuesday the same time as adrians so ill get a dyno sheet for you then.
Jeff seems to think ill see 270ish with a decent tune. Timing is up shit creek aswell.
Edited by Ryanrb25
They do :thumbsup:
thats wierd isn't it....I wonder if that's more the exception than the rule....what happens to the bits when they do fly apart then?
One theory could be that due to the cam overlap the bits make their way through the inlet then straight out of the exh valve before the bits get combusted.....poor cats if that is the case!
Just to clear up, Dan (Inline_6) got pulled over at the end of our cruise last night, but the cop just pulled a skyline over for the hell of it coz her boyfriend is on SAU! No defects, no inspection. Was a good night tho, i DEFINATELY need some better light globes, just cant see sweet FA without highbeams.
 Share
    • Wow its been a while since Ive signed in for sure.  Time gets away... Good question. So much was different between the two designs.  The RB315 was a test to see if I could do it.  Limitations were for the most part due to local machining capability.  Tolerances were an issue.  The 3.15 used a single OD dry sleeve, and was almost the same as a kakimoto spacer plate engine, except I used a plate design similar to the OS Giken plate.  I did not make the top flanges thick enough either.  I can't be sure if it was machining tolerances, or thermal distortion of the sleeves, but the engine did produce quite a bit of blow by.  The modified 87mm RB30 crank was also an issue, and was no where near as nicely balanced as the forged 90mm crank in the 3.4. The 34 was a next level build.  The sleeves were stepped for max thickness, and were a semi-wet design breaking though into coolant completely in the block.  Minimum thickness was 3.75mm and max was 5mm with the 90mm bore, and the new spacer plate also fully supported the tops of the sleeves closed deck style.  This combined with far superior CNC machining, and a cylinder hone finish that the machinist does on 3000hp pro stock cars resulted in no noticeable blow by at all.   In the end the 3.15 was removed to swap in the 3.4.  I discovered the modified RB30 crank had partially sheared the woodruff key on the balancer.  That was all that was wrong with it, but it did make the engine a paperweight at that stage. $1100 to make another crank for an engine with blow by issues was not worth it, considering I'd started playing with all Nitto forged internals instead. I hope you found this interesting.   Cheers, Ian
    • All their parts, when order directly off them are made to order. So you're able to customise fitment of things or delete things. E.g. I asked for no throttle cable bracket, no IACV port, etc. on my plenum. In hindsight, I should have asked for an IAT port/fitting welded on, hindsight no. Should have bought a M2 or 3 lol.
    • 25de in c33 a31 is different to r32/r33 s1 which is different to r33 s2 & r34 so you can vaguely do whatever man.
    • That's the pink sticker type, you haven't said what car so no idea if it's correct, 25de or det is the same in the same model.
