Something like this Steve?
edit. ughhh can never get ebay links to work. Found a better one, but as i have factory Xenon headlights, will i need a HID kit? Theres on on ebay for $73.99 posted.
Edited by Damo_R34
thats wierd isn't it....I wonder if that's more the exception than the rule....what happens to the bits when they do fly apart then?
One theory could be that due to the cam ovtserlap the bits make their way through the inlet then straight out of the exh valve before the bi get combusted.....poor cats if that is the case!
My thoughts are its most likely as you say cam specs but I can't see the ceramic going back in to the inlet UNTIL you jump off the throttle. Could also be something to do with the smaller turbo; turbo being closer to the ports with a direct path unlike the log manifolds.
i work tomorrow and monday!! so no chance of making it down there!! or anywere that means! so after hours job! lol..
can i borrow someones then get one tuesday from u steal it then give it back?? hehe
How much it set you back champ?
$300 for resonator, $200 for fitting and the junBL's were from the forum here for $450 for the pair (but they originally came from exh tech anyhow)...
Probably gonna get custom dumps, a barrel muffler and a high flow cat from them once I get my new turbos...
-D
Well i currently have a friend painting my skirts and rear, but he will be a bit busy before now and autosalon with my stuff, so ill look for someone to paint and fit it for me before August 8th hopefully :banana:
    • Hey @Butters, did you end up getting this clutch in ? I have just ordered to a uniclutch track to go in my getrag 6 speed that’s in my BNR 32
    • I know you don't want to hear this comment, but I can't not say it.  I just can't see 200kw being worth the time and effort. Its like guys with NA cars, putting in headers/exhaust/tune for a massive 20% jump in power. Great, the slow car is still slow and you're down $10,000.  My vote is leave it NA or price in a gearbox upgrade and shoot for at least 300KW, preferably 350KW+.  Now you have a NC that will try to kill you from time to time and will be exciting to drive
    • Ah yep. The main message I want to pass on is, try not to get scared of ghosts when thinking about knock/knock detection.  What I mean is, healthy engines make noise. Knock is also noise. Your knock sensor and ECU combo are trying to determine bad noise from good noise based on how loud the noise is. The factory knock sensors and ECU are not good at doing this.  Modern ECU's are pretty decent at it, however I'd still say that you would want to verify that if your ECU says it's knock, that you actually listen to it and confirm that it is correct.  Are you familiar with the plex knock monitor?  https://www.plex-tuning.com/products/plex-knock-monitor-v3/ I expect you're the type of person that would be very keen to play with something like this. It is great knock detection and you can pop some headphones on and listen to what's going on.  Knock that you've deliberately induced in low load low RPM areas is not really putting anything at risk and is a great tuning/learning/verification tool.  I just thought this was worth mentioning based on the way you were talking about setting up a base map and the Haltech base map settings. There are better ways to spend your time then chasing ghosts and worrying about detonation in scenarios that it is crazy unlikely to encounter it.  I was also wondering, what ECU are you planning to get? Will it be long til you pick it up?
    • This came quicker than I thought. It ain't even 2025 yet.
    • I somehow quoted my post instead of editing it. I regret nothing.
