The Sa Wasteland
Cubes
 Share
Why do you wanna get rid of yours? Are there any alternatives to the Power FC that comes close to it? I guess ill just get one and use Chad's theory, do it all right the first time.
Anyone wanna sell me an R34 Power FC? I hear alot about modding them to suit your application, so rb26 being modded to suit rb25 neo. Whats the go?
Can't mod the rb26 pfc to suit the Neo as they are a different plug. Could possibly do it I suppose if you grab a 25 or 26 plug and then painstakingly swap each individual pin. :P
NEO engines have variable valve timing, so Im not quite sure that they will fit rb26's... I dont believe there were any rb26's released with VVT... will probably need a special ECU to do VVT.... possibly easier to just remap the stock ecu
-D
-D
Nah its not variable.. Its the same as the r33 but 'apparently' smoother in its transition; of which comes down to the solenoid mechanism its self.
You can use a simple $34 window rpm switch imported from the US from a mob that I know of. Its basically a NOS switch; switch on at x rpm then switch off at y rpm.
yea thats what i was gonna say lol
people usually use rpm switch when they use an rb20 remapped ecu on an rb25.
hrm news to me, i always thought they were some special type of comp controlled head ...
will know better next time :P
-D
On a totally unrelated topic, theres a"1993 GTR turbo skyline" in the paper for $10,000. im thinking its not a gtr, so i messaged him "hey mate, is the gtr still for sale?" i get back "yes". hmm, guess ur keen to sell then
 Share
    • Good turnout and some old faces.
    • Wow its been a while since Ive signed in for sure.  Time gets away... Good question. So much was different between the two designs.  The RB315 was a test to see if I could do it.  Limitations were for the most part due to local machining capability.  Tolerances were an issue.  The 3.15 used a single OD dry sleeve, and was almost the same as a kakimoto spacer plate engine, except I used a plate design similar to the OS Giken plate.  I did not make the top flanges thick enough either.  I can't be sure if it was machining tolerances, or thermal distortion of the sleeves, but the engine did produce quite a bit of blow by.  The modified 87mm RB30 crank was also an issue, and was no where near as nicely balanced as the forged 90mm crank in the 3.4. The 34 was a next level build.  The sleeves were stepped for max thickness, and were a semi-wet design breaking though into coolant completely in the block.  Minimum thickness was 3.75mm and max was 5mm with the 90mm bore, and the new spacer plate also fully supported the tops of the sleeves closed deck style.  This combined with far superior CNC machining, and a cylinder hone finish that the machinist does on 3000hp pro stock cars resulted in no noticeable blow by at all.   In the end the 3.15 was removed to swap in the 3.4.  I discovered the modified RB30 crank had partially sheared the woodruff key on the balancer.  That was all that was wrong with it, but it did make the engine a paperweight at that stage. $1100 to make another crank for an engine with blow by issues was not worth it, considering I'd started playing with all Nitto forged internals instead. I hope you found this interesting.   Cheers, Ian
    • All their parts, when order directly off them are made to order. So you're able to customise fitment of things or delete things. E.g. I asked for no throttle cable bracket, no IACV port, etc. on my plenum. In hindsight, I should have asked for an IAT port/fitting welded on, hindsight no. Should have bought a M2 or 3 lol.
    • 25de in c33 a31 is different to r32/r33 s1 which is different to r33 s2 & r34 so you can vaguely do whatever man.
