The Sa Wasteland
Cubes
 Share
ryan if i had the cash i would buy urs!!
i love it! follwing u home the other night and watching ur exhaust popping ambers on limiter was sexual!
perfect example of a 33!
pm me a price hahaha
While i have a spare minute, amongst all this moving house hassle,
id like to give Ryan (Ryanrb25) i plug!
he did my timing belt, and water pump today,
GREAT JOB! did every thing right the first time, and took his time to ensure the job was done properly!
treated my car as if it where his own!
he even organised the parts for me, i didnt do a thing!
best of all, it was by far cheaper than a mechanic!
if you need anything done, and not sure how to do it yourself, and dont wanna pay an overpriced mechanic,
be sure to drop him a PM!
he's a champ
thanks again ryan, she is running sweet!
:P:D
Thanks Craig, Means alot! Was good talkin shit with ya today....
Nice doin business with ya! Nice car to work on!
Be sure to put a trader rating in if ya get the time hehe!
Ryan
Edited by Ryanrb25
Ive done this a few times, I did it on my own car, you have to work out latency etc...Ill work it out and get back to you what to change if you want.
Yeah that would be good thanks Ryan :P Im guessing the injectors are easy to fit, so ill try and do them myself, and the Nismo pump.
Just make sure before you do it chad, The plugs on your standard injectors fit the Sard Injectors, May need to change them, but that may just be Side fed's on the rb25. Just make sure just incase, You dont want to rip the rail out and realise they wont fit. I'll try sort out these correction values and let you know.
yea true, I worked it out to change it to 63 but thats understandable...If its only to drive it to get tuned then that'd be fine, saves towing it. I changed mine and told jeff to go over it and he said they were correct.
Has anyone bought items of a store on ebay called Lewis engines performance engines1? they have RB 20/ 25 ARP head stud kits for $265 + $15 postage.
Also What should i be paying for a r33 gts-t OEM thermostat or should i go nismo, iv herd running a nismo thermostat can cause probs with a street car?
 Share
    • Good turnout and some old faces.
    • Wow its been a while since Ive signed in for sure.  Time gets away... Good question. So much was different between the two designs.  The RB315 was a test to see if I could do it.  Limitations were for the most part due to local machining capability.  Tolerances were an issue.  The 3.15 used a single OD dry sleeve, and was almost the same as a kakimoto spacer plate engine, except I used a plate design similar to the OS Giken plate.  I did not make the top flanges thick enough either.  I can't be sure if it was machining tolerances, or thermal distortion of the sleeves, but the engine did produce quite a bit of blow by.  The modified 87mm RB30 crank was also an issue, and was no where near as nicely balanced as the forged 90mm crank in the 3.4. The 34 was a next level build.  The sleeves were stepped for max thickness, and were a semi-wet design breaking though into coolant completely in the block.  Minimum thickness was 3.75mm and max was 5mm with the 90mm bore, and the new spacer plate also fully supported the tops of the sleeves closed deck style.  This combined with far superior CNC machining, and a cylinder hone finish that the machinist does on 3000hp pro stock cars resulted in no noticeable blow by at all.   In the end the 3.15 was removed to swap in the 3.4.  I discovered the modified RB30 crank had partially sheared the woodruff key on the balancer.  That was all that was wrong with it, but it did make the engine a paperweight at that stage. $1100 to make another crank for an engine with blow by issues was not worth it, considering I'd started playing with all Nitto forged internals instead. I hope you found this interesting.   Cheers, Ian
    • All their parts, when order directly off them are made to order. So you're able to customise fitment of things or delete things. E.g. I asked for no throttle cable bracket, no IACV port, etc. on my plenum. In hindsight, I should have asked for an IAT port/fitting welded on, hindsight no. Should have bought a M2 or 3 lol.
    • 25de in c33 a31 is different to r32/r33 s1 which is different to r33 s2 & r34 so you can vaguely do whatever man.
