The Sa Wasteland
Cubes
 Share
if that was the case, then 1/2 psi extra boost on a car with STD internals would take care of that.
Peeps generally do a rebuild with forged pistons and aftermarket rods to be able to cope with more HP, RPM & strength.........not for better response.
Alot of people dont realise this.
Driving home today i noticed the RB30 in my daily driver has done a bottom end bearing....sucks considering its a really tight motor, Brand new head, no lifter noise what so ever. So thats a job for the weekend. :laugh:
ive teed it up with ryan to have my new rotors installed when they arive, now to find a decent set of pads, and fluid.
:laugh:
Craig, Steve Madaz & I are doing our brakes soon with the EBC Redstuff....I've looked long and hard for a pad that has good cold bite for street use that's reasonably quiet, has reasonable fade resistance for light track work, low dust effect and without being too aggressive on rotors.
If you remember I posted this thread Brake Pads and the general consensus from the likes of Evil34, PureSX, Ryan & Jenkies (just to mention a few) was that the EBC stuff is pretty good, not to mention cheap and available on the Groups Buys .
The EBC Greenstuff seems to be good for street use but the Redstuff would be better for street/light track work, plus they're ceramic so very quiet & low dust. The Yellowstuff seem the way to go for heavier track work but also dustier, noisier and more aggressive on your rotors.
Hope this helps
If anyone would like to come down to Villie's this Friday night for a coffee and a chat ill be there 7pm i posted it up in the go kart section for them and decided to put it here to
Thanx chad
 Share
    • Not easy to find pics from 15 years ago, but here is a partial one. Keep in mind that it curved immediately from the airbox, then kept a straight line for the MAF to read correctly, followed by a 45 degree bend straight down to the turbo. This connection was the most difficult as it had to twist as well as bend to meet the almost vertical straight section of the intake.
    • Yes, well, wrt a wheel alignment, there are two types. Either: You have very little added adjustables, in which case the alignment can be done by anyone in any tyre shop or equivalent, and will only take 30 minutes, and so there is no reason to even consider leaving the car there. OR: The alignment is a major exercise because you have adjustables everywhere and so you will need to be taking it to a shop that is skilled and experienced at setting up race cars and the like, and you won't need to worry about leaving the car there.
    • does anyone know the specs of the R35 master cylinder, rear ratio and knee point? the BM57 is a 0.4 rear ratio with a 435psi knee. I'm looking for someone with a much lower knee pressure. the piston area of the R35 brakes isnt that big so might not work for me but this is interesting.. the other option for me is a GU patrol master cylinder and booster and do the prop valve externally.
    • It sounds like by avoiding maintenance you may be doing more damage than a hypothetical guy in a workshop taking it for a spin. Not sure if you are just being paranoid or things are actually that bad in the US. Find a reputable shop not run by dickheads. Look for people that take pride in their work. Stick around for the day if you have to
