its got jaggies and stuff but it was going to take a bit to get it 100% im not an artist just like playing
Thanks Stevo.....I'll give it a go.......looks good bud. :P
Hey no probz Dave......I reckon Patrick is organizing a DVD for me so don't go out of your way bud, but I'd be curious to see what's available in Adelaide next time you're there. :)
KISIN - Yes i actually have GTR fronts in mine but there is no differance in the front from GTSt to GTR
Yeah it would still be there Jess but sau has a bad habit of making links go bad if you just copy and paste without coding them :(
Oh :D again..This is the first time it has done it to me..
All good cause Sled found them on ebay anyway!
I'm excited about Go Karts and catching up with you SA folk :woot:
There might be no house purchase for me this month :)
House at auction went for way more than I was willing to go (which was well above market value)! :D
House I put an offer in I had a second inspection last night on and there's a few things wrong with it. Getting a building inspector to go thru it early tomorrow morning (before I got interstate), and I've instructed him to look for water damage in the ceiling and down the wall cavity. I strongly believe there will be hidden damage, and the owners thought paint would cover up anything. Considering the vendors are asking $5K above median price in the area (on par with Cheltenham houses) and especially $50K above suburb prices (houses in Rosewater range $310K to $330K average) ... I do not believe it will be worth $375K even with the extension (which I suspect does not have Council approval). :down:
Shopping for a house is so much hard work ... jesus, there are some real disappointing homes out there ;)
There is one final house I'm looking at in the area well within the market range and looks to be in better condition. I might arrange an inpsection next week when I return. If nothing comes from this one, I'm giving up looking until the end of the year. Everyone knows the housing market is on its way down, and most vendors are trying to get as much as they can now despite there being some problems with the house!
I'll have pleasure telling the vendor I'm retracting my offer due to hidden faults with the house they were aware of, if it comes to that. :P
Edited by RubyRS4
WOOT.. 302rwkw 17psi
Best part though...
3500rpm = 200rwkw
4000rpm = 265rwkw
Comes on super smooth no snapping and actually really easy to get the power down.
The 2" FMIC piping and 450x300 small FMIC was causing a few issues and wouldn't allow us to push more than 17psi in to it up top. :D
Not to replace the fmic and its 2" skinny arsed piping :P
Best part though...
3500rpm = 200rwkw
4000rpm = 265rwkw
The 2" FMIC piping and 450x300 small FMIC was causing a few issues and wouldn't allow us to push more than 17psi in to it up top. ;)
Not to replace the fmic and its 2" skinny arsed piping :D
Very Nice!!! :P
NICE joel!! im sure ur a happy man..
whats next hahaha?????
Thats a silly question... :)
E85 haha
+ FMIC with 2.5" piping.
The cams have really woke the car up.. Right off idle it feels much more responsive, spools the turbo earlier etc. I must admit I was a tad scared the 265/263 9mm regrinds would kill low end but its been the complete opposite.
Best thing.... I've just pulled 400km's out of a tank and almost a 1/4 of that tank was on the dyno!! :D
Thats a silly question... :blink:
E85 haha
Best thing.... I've just pulled 400km's out of a tank and almost a 1/4 of that tank was on the dyno!! :huh:
hey Joel.....did you have to retard the exh gear to compensate and bring the power curve back to the left?
I'm abit confused, cause even though 9mm is not huge lift, when I went to school, bigger overlaps always caused a shift in rpm in a northerly direction.......maybe it's more to do with your tune than the cams cause I always thought that better response is not generally a side effect of bigger overlaps :)
I'm abit confused, cause even though 9mm is not huge lift, when I went to school, bigger overlaps always caused a shift in rpm in a northerly direction.......maybe it's more to do with your tune than the cams cause I always thought that better response is not generally a side effect of bigger overlaps :blink:
Regardless of the size of the cams the way they are setup they run less overlap than the R32 RB25DE cams (8degrees) I previously had in there.
From memory they were 240duration inlet 7.8mm lift and 232duration 7.3mm lift. Inlet had an LCA of 112 degree's and exhaust 117 or 118degree's. Being a total of approx 8degree's overlap.
The new cams... Inlet LCA 110 exhaust 115. Overlap is 4-5degree's so even though they are bigger cams they are setup with bugger all overlap.
The Inlet LCA and exhaust are exactly the same as how JUN or HKS I believe setup their RB20DET cams.
Less overlap helps turbo spool improves bottom end which is most likely why I have not lost any fuel economy or low/mid power yet still picked up decent top end due to the 265duration and 9mm lift. I presume. :S
Still got some tweaking to do it was only on the dyno for approx 1hr. It wasn't worth spending any more time on it as the FMIC is crap and causing problems. Most likely the IW 1bar actuator is not able to hold much more. Much the same as the problems Dangerman4 experienced with his IW garrett housing. Needs a nice stiff actuator.
    • Among other things yes. Making sure to either use an oil pressure regulator or the right restrictor size for your oil pump/range of oil viscosities you intend to run, making sure you plumb the lines correctly, turbo should be placed such that it siphons properly even when the water pump isn't turning so you don't boil coolant in the turbo after shutdown, oil return should be low resistance and also preferably picking the one that is most likely to return to the pickup as opposed to some other irrelevant part of the pan. It's far from impossible to figure this out but I have seen people really, really struggle and if that's the case it's easier to just take the path of least resistance. To me, bolt-on twin turbos are a fixed cost whereas single turbo is almost unbounded.
    • Latest round of updates on the car. I purchased and installed a SWS clutch slipper to help with 60ft times and got some second-hand good condition 275/40R17 Hoosier DR2 radials. Test and tune in November showed the tyres were an upgrade over my over 15 year old mickey Thompson's and I got a 1.8 second 60ft and pb et of 11.71 but even then, that run wasn't great due to rain and driver error (the event got called off 10 minutes later fast forward to the weekend just gone 25th of Jan and there was finally a break in the weather to let racing happen. The first run the track was slippery and only managed a 12.1@129 Second run the track was better and got a new pb et and mph: 11.54@131   Lith and I then worked out that I installed the previously mentioned clutch slipper incorrectly and its never been working, and I had just been dumping the clutch the entire time, we also noticed it was on street boost and not race boost. So I lined up for a third run with the car turned up in the first two gears, but the passengers side axle objected to clutch dumps and left the chat which stopped my weekend.   so there will be another attempt in the future once I replace the tyres as they rubbed and are stuffed now. but a low 11 should be on the cards.
    • Ceramic coating and heat shielding, you mean?
    • Turbos don't require pulling the motor apart so that's "easier". I would recommend the Nismo R3 turbos instead if you want to do stock twin turbo. It doesn't make as much power as the 2530s but it's only like ~50 whp off the mark and should have better response (ball bearing CHRA, slightly smaller turbo). A local that went with a Garrett G30 and 6boost manifold recently nearly burned his car to the ground after the hood insulator started melting and and burning so if you go single turbo I recommend doing a lot of research and validation work to make sure you don't do the same.
    • New rear lights, filler panel sprayed, cleaned and back together    before, during, after shots 😍
