Same here!! I finally had all my 6 injectors replaced with orginal GTR items. The current ones were cracking (don't know how and why, but apparently this is common now) They're $330 per injector from Japan! It's crazy! I could get a full set of Sard injectors with bigger cc for the same price of 3 original injectors! Problem is, I'd need a aftermarket ecu to run them :D
or a remap? either way, it would end up costing twice as much. did you buy new ones? i thought you would be able to pick up some cheaper ones locally?
heres a pic of my rims too, all cleaned up and safely in aus with me!
Edited by ted180
VERY nice choice of wheels there! :D
thanks!
for people wondering what they are:
Weds Kranze Cerberus 1. (rare now because the Cerberus 2's are out. the 1's are alot better, the 2's only come in chrome, which is lame!)
18x9.5 and 18x11, +10 all round.
i love them!
Edited by ted180
hey Cronic... Just priced up a power fc for a R32 GTR for a mate on here for $900 del. If u need one i can put a order in for u to :D
Oh really? Can u put in an order for me also? Will have some tax money that will need spending if a few weeks. Was going to get one off ebay for $1,095. For $900 i can add a few other things to the list of 'things im going to buy with my tax money'.
hey Cronic... Just priced up a power fc for a R32 GTR for a mate on here for $900 del. If u need one i can put a order in for u to :P
Only $900? I would say Yes, but my funds are zilch at the mo'. I need my new exhaust before I start on anything else - my baffles inside the cat are wobbling all the time now - they're bound to just come off anyday now and shoot out the back... although, I doubt this could happen.
Turbo-back exhausts on twin turbo's are so expensive! It's like $700 just for the dump pipe!
What is the standard compression for an RB25det?
Did a compression test on a mates car yesterday but i don't know what the factory specs are and i only have silvia/180sx manuals.
Results (psi); (They look very good IMO)
1- 167
2- 168
3- 170
4- 170
5- 169
6- 168
What sort of upgrade is an N1 compared to standard Pete?
More fins in the water pump (2 more from memory)
Close....other way around actually. N1 pumps have less but larger fins. They don't suffer cavitation issues at high rpm and apparently flow better at lower rpm due to the bigger impellar with less fins. :P
1- 167
2- 168
3- 170
4- 170
5- 169
6- 168
Looks pretty good Dale....gotta be happy to be within 2-3 psi :P
Well my car goes in saturday to have sideskirts fitted and front bar fitted and painted! Apparently theres another little white support infront of the reo that has to come off for aftermarket bars, so the front bar will supposedly fit! Will be done before autosalon, yay.
got my car back from smooth garage today from a manual conversion!
so very happy :P
edit: also getting a few more bits and peices done friday. hope to get it all back better then ever by the weekend :P
Edited by Import S13
Where are ya getting it sprayed? I still need to do some touch ups ... ;\ dunno if I'll be able to afford it before autosalon tho
-D
    • Unfortunately,  it feels like it's been on the decline for nearly a decade. Especially as wallet racing became popular with them(biggest wallet can pay off a car that wins). It seems like a different mindset kf ownership these days. But, hopefully people like yourself keep some of the skyline scene alive.
    • A bit of data is always good, beats the Facebook experts with their opinions Although the kWs aren't anywhere near what you are after, it should give you a good indication. I have Bosch 1480cc injectors, often called 1650cc (only when run at 4bar). I run mine at 3bar base so I don't thrash the fuel system. Up top, making 437kW with boost dropping, injector duty is at 69% on E80 (might have had some residual 98RON in there)
    • I have some downtime due to winter, and just wrapped up converting the car over to flex fuel. We don't get E85 at the pump over here in Canada, but I will be running Ignite E90 Race gas. I'll be mixing it with 99-100 RON pump gas and shoot for 50% ethanol content, up to possibly 85% content if there's any noticeable gains. Here's the question. Most I'll ever want to hit is ~600rwkW. I've currently running 1200cc injectors and want to keep them under 90% duty cycle. As per some online injector calculators, I should be good with 1200's well past 600rwkw on E85. As per other calculators, I'll need 1600-2000cc's. The variety is rather amusing.  With you Australians having E85 at the pump, what realistic duty cycles are you seeing in those kW ranges on E50 & E85 on your injectors? Thanks,
    • No issues here with my PRP gears in an OEM pump housing. I did confirm all housing clearances were to spec prior though. Cheers.
    • Thread is a bit old but figured id give my input anyway just incase. Have had lots of water problems in my R32 and was getting sick of wet tools in the boot and water filling up half my taillights. I ended up finding that whenever my car had been repainted they didn't reseal the taillights to the body of the car so water was just flowing straight into the boot, this is amplified by all the water around the bootlid being directed down to the taillights so would get pretty wet whenever I washed the car or it rained. You could probably use silicone to seal them to the body but I think from factory they use a roll of automotive grade butyl rubber. Hopefully this helps you if that ends up being how the water is getting in on your car!
