;) Anyone hear on the radio today about one of the Veronica girls having a naughty picture find its way onto the internet? I just love how these things come out
they showed the pic on sunrise this morning. it was shit, it was like shoulders up naked, so not worth it.
there was a second pic, but apparently it wasnt one of the veronicas, just someone that looked like her.
did you buy this off karim? who bought it off one of the guys at smooth garage...
looks good dude
yeah got it off karim, needed a fair bit of tlc, so i put it in the shed for the last few months and got stuck in. ill give it a wash and polish then take some decent pics. engine bay looks 100% better then when i got it. completely
re-wired it, painted anything that look shitty, tidyed up anything that needed it.
that looks awesome ted!
thanks man. let me know if when your down this way and well meet up!
tyres work out ok ted?
yep, thanks for the advice! helped heaps.
Edited by ted180
who's the noob who crashed their Black R32 on prospect Rd into a brick fence being a hero reppin SAU stickers...hang your head in shame ya dooshbag
Wasn't me.... ;)
Mine struggles to get sideways as my right foot doesn't allow it to get that out of hand.
I don't think they'd put their hand up for that admission ;)
Just keep an eye out for the member who doesn't show up at cruises for a while and is shopping for parts :)
i think thats already been discussed in the spotted thread?
    • Very nice - I also have a 92 GTST and hardly see any others around these days
    • When I need something else to edit, I use Movavi. A friend who does video editing on a daily basis recommended me) it's an easy video cutter to use for beginners
    • I need to edit some videos for work but I'm not good at all this. Which video editor can you recommend?
    • I think you're really missing the point. The spec is just the minimum spec that the fuel has to meet. The additive packages can, and do, go above that minimum if the fuel brand feels they need/want to. And so you get BP Ultimate or Shell Ultra (or whatever they call it) making promises to clean your engine better than the standard stuff....simply because they do actually put better additive packages in there. They do not waste special sauce on the plebian fuel if they can avoid it. I didn't say "energy density". I just said "density". That's right, the specific gravity (if you want to use a really shit old imperial description for mass per unit volume). The density being higher indicates a number of things, from reduces oxygen content, to increased numbers of double bonds or cyclic components. That then just happens to flow on to the calorific value on a volume basis being correspondingly higher. The calorific value on a mass basis barely changes, because almost all hydrocarbon materials have a very similar CV per kg. But whatever - the end result is that you do get a bit more energy per litre, which helps to offset some of the sting of the massive price bump over 91. I can go you one better than "I used to work at a fuel station". I had uni lecturers who worked at the Pt Stanvac refinery (at the time they were lecturing, as industry specialist lecturers) who were quite candid about the business. And granted, that was 30+ years ago, and you might note that I have stated above that I think the industry has since collected together near the bottom (quite like ISPs, when you think about it). Oh, did I mention that I am quite literally a combustion engineer? I'm designing (well, actually, trying to avoid designing and trying to make the junior engineer do it) a heavy fuel oil firing system for a cement plant in fricking Iraq, this week. Last week it was natural gas fired this-that. The week before it was LPG fired anode furnaces for a copper smelter (well, the burners for them, not the actual furnaces, which are just big dumb steel). I'm kinda all over fuels.
    • Well my freshly rebuilt RB25DET Neo went bang 1000kms in, completely fried big end bearing in cylinder 1 so bad my engine seized. No knocking or oil pressure issue prior to this happening, all happened within less than a second. Had Nitto oil pump, 8L baffled sump, head drain, oil restrictors, the lot put in to prevent me spinning a bearing like i did to need the rebuild. Mechanic that looked after the works has no idea what caused it. Reckoned it may have been bearing clearance wrong in cylinder 1 we have no idea. Machinist who did the work reckoned it was something on the mechanic. Anyway thats between them, i had no part in it, just paid the money Curiosity question, does the oil system on RB’s go sump > oil pump > filter > around engine? If so, if you had a leak on an oil filter relocation plate, say sump > oil pump > filter > LEAK > around engine would this cause a low oil pressure reading if the sensors was before the filter?   TIA
