The Sa Wasteland
Cubes
 Share
lol at the valve cap problems! iv actually had some re apear on my car after a few months lol,they must have liked the new ones i put on there better lol.its just about always the really young kids that do it tho i recon.
im a desk jokey at telstra atm,only been here for a few weeks tho.i was at autobarn before this.im just happy that i get a chair to sit on all day insted of standing up for 8 hours a day lol.
cheers cubes - hows the family?!
yeah just retuning after the hiflow 617cfm Random Technology cat converter install a month ago - should have fixed the massive boost drop issue nicely
everything else is done, nicely and not too expensive. will handle 16psi daily no issues
getting the rocker cover gasket, attessa oring & another leak fixed also
hit the gas with my mum in the stag yesterday on the way to a Pain clinic appointment, pushed her back in the seat lol and stopped her chatter (for a second hahaha)
then at the lights hit the stoppies, she actually commented wow it goes really nice (too low, too bumpy, but nice nonetheless lol)
cant afford, really, to drop in the injectors this time round. if anyone wants them they can, but next service perhaps...... :P
its the 8/8/08 today!
Don't pat a black cat! Don't walk under a ladder! Don't... oh hang on... that's Friday the 13th, hey!
Haha
How many times do people write hahaha or lol or lmao... but they're not actually laughing? 80% of the time I'm not actually hahaing when I write haha! :P
Ahh yeah got ya :P
Haha i may not laugh when i type haha or lol....well sometimes i do. but usually i just smile :P
I just noticed your gallery link in your sig, I just took a quick squiz... and gee!! You've got some amazing pictures!! They're awesome!! very nice work there.
I used to love photography, but ended up dropping it in year 12 :D
i brought some puma race shoes with crystals on them :P
they are so cute im wearing them tonight for the go karts lol
lol they will get ruined kelly! hows the little man doing?
 Share
    • Shaft speed would be the same, however it's how long they hold it there for and repeated conditions. FWIW half way down the main straight at SMSP I'm bouncing off 4th with a 8600RPM limiter. That shaft would be spinning at 8600RPM for a few seconds before I need to smash the brakes, by T2 it's getting close to that speed again. Now a drag car/roll race car would see that shaft speed for a 1 to 2 secs then they would coast, hit the brakes and that's it.
    • With same diff ratio, tyre diameter and road speed, the tailshaft rpm is the same regardless of the gearbag's ratio. Given that very quick drag cars are probably doing similar road speeds to the fastest circuit cars (circa 300 km/h), and there will be many of either category that can't go that fast and so you'd have inummerable matchups between drag and circuit car speeds at smaller numbers, and given that they are probably using rather similar tyre diameters and probably using similar diff ratios, and...where any of those numbers were different they could quite easily be in opposite directions thus cancelling out.... I think you'd find that there'd be more similarity than difference in tailshaft speed between these two use cases, no?
    • they might see those prop shaft speeds for 1 to 2 secs only
    • A year of slogging through this bearing issue and finally fixed. What a nightmare. The oil pressure increase did not fix the problem. If you would like to read all the details in case you ever run into a similar issue visit my thread on Yellow Bullet. https://www.yellowbullet.com/threads/continuous-rod-bearing-issues.2689569/?post_id=74193031&nested_view=1&sortby=oldest#post-74193031 In the end the rod bearings themselves were the issue. I had switched from ACL (first engine) to King because that was all we could get at the time and I thought nothing of it. Put the ACL's back in after a year of taking the pan off multiple times to change many things. Issue resolved. Can't believe it was just the bearings themselves all along. It has now been about two years since I drove the car on the street or had it at the track. At some point I had installed all solid and spherical bushings in the rear but had never aligned it since it just went on and off the dyno. Alignment was the first thing to do. (Old photo but same concept) Then I took the transmission out and went through it. This was my first gearset install and I've done about 15 since this one and learned a lot and wanted to apply some of these tweaks to mine. The aftermarket shift forks take very well to some modification and I wanted to make that change. Shifts are now super smooth and no having to find the gear. I also recut the 5th and reverse shift sleeves - always wanted to try this and see how well it works. It works very well! No grinds or having to do a second attempt going into reverse and 5th is perfect. Before During After Going back in In rummaging through my spare trans parts box I found the only parts I've ever broke on a stock trans; the 3-4 shift fork - twice!
    • It also depends on gearbox ratio. Those drag cars running 7s passes aren't doing it on an overdrive gear ratio (probably). 1:1 is "fine", the critical RPM for a 50' single driveshaft in chromemoly is 6900rpm.... ....but when you shift into 5th and use 0:73 or 0:8 it all changes. Do you know their rear diff ratio? etc. That's the stuff that matters with regards to it. Whether it actually matters given your use application is also relevent. You may never get into those scenarios, like most ruined GTR's from Western Sydney don't :p
