The Sa Wasteland
Cubes
 Share
iv had it with the weather now! i washed my car before and not one drop of rain while i was washing it,i just finished shamying the entire car and was about to put it under the carport when it just randomly poored with rain and soked the car again!! :banana:
Hey what's happened to Darren "Deluxe"??............have one of you bananas upset him or something??........I miss the lanky fella.
Daaaaareeeen phooooooone hooooome!!!!!
Im tired, been at autosalon all day kicking rude people off our display, can't you see that it's roped off? geez. the graham west dyno has low balled everyone, mine only made 165rwkw :banana:
bout time those autosalon dyno's were realistic.
bahahahahahhaa
I think what Ryan is saying that the autosalon dyno in the past has read more generous. Im just disappointed i made 182rwkw a few weeks ago, then 165rwkw today. oh wells.
yeah steve I got a PM from Jess and I'll try and make Villis as well but I've spent most of the day on the shitter unfortunately.
I'll give you or Jess a ring later to see if you're still there.
Hey Ryan, do you know how to fit a set of drop spindles to the front of a hilux???
nah sorry chad, if your deserate i know of someone who would be very keen to do this for you...she's a tech at CMI west side toyota.....if you get stuck!
Hey guys, i need to find these four connections on my ECU. Ive never touched the wiring on my ECU before and just wanted to make sure that i have the right wires.
I need:
+12V Ignition Switched pin
Ground Chassis 0V
Oxygen Sensor signal
Airflow Meter signal
Now ive found this ecu diagram pinout
Now im pretty sure that for the 12v ignition switched im looking at pin 45, and for Ground 0V im looking at pin 10 or pin 20. (Please correct me if im wrong)
Airflow meter signal is pin 27.
Im not sure where the other pin for oxygen sensor is. I found another ecu diagram with the oxygen sensor on it (Pin 55) but im not sure as the diagram above says 55 is nothing =/ I know how to check these with a multimeter but i just wanna make sure first =)
Im tired, been at autosalon all day kicking rude people off our display, can't you see that it's roped off? geez. the graham west dyno has low balled everyone, mine only made 165rwkw :)
It's Mainline Dyno's are more accurate to real HP than the dynodynamics ones. Everyone is in the same boat though and it also makes "SLO 33"s 465kw more impressive, It would be more like 510kw on a DD dyno.
Edited by D_Stirls
 Share
    • I can be grumpy!  After owning one of the first GTRs in the country, I was bitten by the nostalgia bug and started the hunt for a GTR again.  While I could have bought a car locally, I wanted to experience the search for a car in Japan and bidding at auction.  The above videos document my experience to date and hope forum members find them interesting and informative.  I was after a low mileage, completely stock car in the launch colour and am pretty stoked with what I got!
    • Sounds like AFM or TPS issue. What are the voltages at the TPS like? Have you done any diagnostics other than slapping parts at it?
    • I am actually chuckling about that out loud!
    • It's a race to the death between the oil pressure and the fuel pressure (from the tailshaft spreading the fuel line out across the underside of the car).
    • All Christian was saying is that if your OP here was to dump youtube content to increase views and adsense revenue, then we take a dim view to being used like that. It's just that the apparent mode of operation matches the mode described by Christian and used by others in just the recent past. If you're hanging around and contributing, then no foul. You can be a grumpy old man with the rest of us. It may well be better suited to the importing section - but that's for you an Christian to think about (more than me to think about, anyway).
