rang you today roo no answer wondering if you still want a o2 sensor
>>Fixed eBay Link<<
Argh! That was your number? Sorry dude. Been at TAFE this morning/early arvo. So I had to ignore my phone. Got to work and got busy.
I made the transfer this arvo. You should see money tomorrow! :) Sorry for not advising. Sorry for anyone I've held up too. ;)
dont sweat it man due to SAU being down for like 4 days i had sort of planed a small extension should order them next monday and pick-up what he has in stock hopefully all going well
Chad - yes money has gone through i updated the o2 thread
Ryan - did you still want a RB25 sensor
Luke - you still in need of 2 sensors
Pete - get off the potty man :) need sensor order check ;)
Any1 put in an oil catch can before?
what did you guys use to block the holes?
i read to use some threaded plugs?
any1? cheers
i didnt block any of the holes, i just ran the catch can in between the passenger side rocker cover and afm pipe
Pete - get off the potty man :wave: need sensor order check :(
Sorry mate.....I rang JMS and asked for Brady but he went home early and the other guys had no idea.
I'll ring Brady again tomorrow bud.
yeah pretty much might have to re-pin one of the sensors plugs but there a little cheaper for R33 gtr than R32 gtr :P
Steve that's a yes to the sensors, have you sorted out all the details?
cool cheers man
JDM Yo! at least if the police cant read it tell them your car is the biggest tyre size
The placard I bought from nissan had all japwriting on it.
Only legible information was the tyre size. :worship:
    • This piece is obscenely discontinued. I honestly hate the frameless window design because the rubber gets stressed and the guides as well every time you open and close the door.
    • I wouldn't be concerned at all, other than to suggest having them flow tested when you receive them to confirm they are reasonably similar, and then put the highest to lowest flowing ones in cylinder 6,1,5,2,4,3
    • I’m only posting this cause I thought I had seen a bad review on these somewhere before. Any feedback? Would you guys recommend that if I do buy these I send em to RC to have em checked before installing. Or any other suggestions?   https://www.ebay.com/itm/114009965865?mkcid=16&mkevt=1&mkrid=711-127632-2357-0&ssspo=JDl-15yLQ8C&sssrc=4429486&ssuid=QTzlFXB1S-S&var=&widget_ver=artemis&media=COPY
    • They see me rollin' they hatin'....... Took me most of the day to make the necessary mods to the mounts to make them fit the car.  Fortunately I was able to just use the mounts that came with the rotisserie. The rear ones are really secure, the front I feel i might reinforce a bit more as it doesn't seem like enough attachment to the vehicle. I'm sure it's fine but better to be safe than (extremely...) sorry.  I drilled and tapped thread into additional M12 holes to each car mount where it attaches to the rotisserie as an extra fail-safe. Without them the side to side movement is just restricted by the allen head pinch bolts, nothing actually goes though the beam. Does now! I still need to adjust the rotisserie to get the car centred in terms of centre of gravity. If it's too high or too low relative to the rotational centre line of the car, it will be like a turtle and roll onto its back or as it currently sits, I dont think I'd be able to rotate it as it sits as it needs to lift the whole car up as it rotates. Ain't happening... I'm going to be nervous as hell the first time I go to spin it on its side...
