Ok, installed an air vs fuel ratio meter that i got form jaycar... now its not the most accurate thing out there... but the fact that i built it and wired it in
merits some satisfaction :P Just thought i'd share! :D Oh coincidently the alarm beeps when i need to change gears! WOO
Edit* Looks cool at night too!! with all the little LED's dancing around XD
Joel you need to learn to read thats twice now you've been given an answer today and you still asking the same question
i told you up the said check your afm elec. Cleaner might not be enough Damo there over 20 years old
my car almost got defected :D
luckily i got an awesome cop who has given me a week to get EVERYTHING fixed
he did say if he sees it on the road next week in the same condition he will defect it.
oh and my suspension is too low :P which is weird coz no1's lowered it unless my
brother did it it without me knowing lol
yes, yes i do. went from a job with random hours at a low-ish pay rate to working the last 3 month with consistent hours at a high-ish pay rate this = mega tax refund!!! =)
same! thankyou ATO :P
What do you mean Joel? The plug
you need to unbolt the whole lot and spray the needle on the inside and dont use degreaser
lol damo ner ner...
could be.... i pulled the top AFM off to clean it but it was already sparkling so i didnt bother about the other 1.... maybe its worth looking at...
those chromies on your car damo look crazy when the spokes are painted with 2pac gloss black! a mate of mine did it and they're not bad at all
I was going to say the same thing :P They look pretty good but would look alot better with black spokes
200-300 for the front bar sprayed maybe?
but when i went to arnedale to pick up my mum there was a freaken RBT on the street where the carpark is where bunny had her cruises! cop asked if i had a bov i said yes and it's stock, he let me through :P
    • I'm firmly on the "zero compliance is good compliance" for FUCAs. I'd be looking to solid metal joints even if the primary reason for having them is because they facilitate the twist in the arm. I have never been more happy with the way the front suspension behaves than I have since I got rid of the FUCA bushes. Even the thin little (short lived) poly bushes in the Whiteline adjustables have too much compliance for my liking. It probably won't be long before I have sphericals nearly everywhere, probably including both top and bottom arms in the rear, and I'll start complaining about the increased costs for dental work. But I will be enjoying the driving more, I'm sure.
    • Plus, you'll get great experience in bedding in pads!
    • I have offset Nismo brackets so the fact the gktechs can pivot is less important to me. I have 170mm JIC arms with bushings - but they provide no adjustment and I'm not sure whiteline eccentric bushings will fit them (I don't want to ruin the bushings currently in them to find out). Ideally I want something with bushings + adjustment; hence why I'd like to find a pair of these. Unfortunately they aren't easy to find.
    • @Vee37 How much do you really care about finding these pads again? If your pads are quiet, work well and produce minimal dust, really isn't that enough? If you are set on finding the exact pads again, I suppose I'd do something like this -  Visit your local Jax, find out what brand of pads they carry. If the Jax workshop you previously went to had the pads on the shelf, then you can almost guarantee it will be of said brand.   I'm guessing you don't have the receipt for the previous work and pads. Can you visit a Jax workshop and see if they can look up your previous job to see what pads were fitted?  Still no luck? Put your stalker hat on, find the staff that used to work at the Jax store and ask them. Talk to local workshops, try to find out where the mechanics went to. Talk to Jax workshops, maybe they relocated to another workshop. When it comes to mechanics, its a small world. You'd be surprised how easy it is to track someone down. If these ideas don't work, shit will start getting crazy very quickly.... You could find out every brand and model of pad that fits that car... and try them individually ticking each off the list if it wasn't the one you were looking for.... If you go down this path your going to want to learn how to swap pads yourself, it is very easy, takes minimal tools and space. If you have room to park the car you have room to swap the pads. Plus you have the advantage of making sure all the brake hardware goes back in so they won't squeal!
    • You miss spelled bearings...
