so my car has been at the mechanic all day, cant get it to cut out at all (3x15min drives + 45min drive)
what happens? cuts out on the way home!!!!!!!!!!!
has any1 got some GTR AFMs for sale? quoted $400 for pair @ wreckers????
steve wally only has the pink stickered AFMs i need the orange.
just pulled off the AFMs they look i good nick, all wiring seems to be fine i dont have that elec tool to check voltage tho :S
about to clean them now, i did how ever find a small tear in 1 of the vacum lines going off of 1 of the blow off valves! could this be the problem????
i cant find the other end of it tho :S
could this have caused my problem????
doubtful. im no mechanic but im guessing a tear in a vac hose will just impact performance as the engine runs a negative vacuum when not on boost (depends where the tear is I think).... I had the exact same problem as you and the mechanics couldnt get it to misbehave... so I just changed the suspect afm myself to see if it was the culprit and i've never had a problem since...
-D
