Doesnt look toooooooooooo bad... I was thinking it snapped in half. Contacted the guy yet? Get it done somewhere reputable that'll charge an arm for it and have the insurance send that bill to him lol
Rhys, no damage.
Vu, i tried to contact him on tuesday night, straight to message bank. Made a police report yesterday, then tried to call again last night, straight to message bank. left another message. Justcar insurance advised me to get a quote, and if he doesn't contact me then ill go through insurance.
If i need 3 quotes ill go through the guy who painted my kit (Pro Finish Custom Paint), All Type Crash and Doyles.
got my exhaust done today, its pretty rad. feels like its free'd up quite a bit of power over the old system.
2.5" pipes, jun x-pipe, lukey resi's. cost $800, but i was quoted anywhere between $1100 and $1300 at local exhaust shops, and $1400 at fisher performance ;)
well worth the trip out south to get marky to do it :)
Rhys, no damage.
find out where he works haha.
my parents had this problem with a stupid woman that reversed in to my mum's car
my brother (who had the car when it happened) saw her do it grabbed her details
tried ringing her a few times went to the machine, so they then said if they have to
they'll ring her work (which funnily enough this happened in front of), she then rang
us back LOL
I'm dying to take the Italian out for a ride!
Gunna get insurance for the Mv Augusta tomorrow, so I can ride her on the weekend. :P
Was with Swann Insurance, but they suck balls. I've already crashed her once, and Swann gave me nothing but headaches. But no way in hell I'm riding it without insurance :)
BTW doing a track day at Mallala on the 20th this month, if anyone wants to see me crash :)
    • Not noticeably. Arguably, the catless turbo is going to work harder in a different direction, as it will spool up faster, go to higher speeds more easily. Only if it was tuned in the original condition. If it was a stock tune, using the AFM before and after the cat/dump change, then no, no retune needed. If the car is running on a MAP sensor, then it might well benefit from a retune. It might even run a little dangerously without a retune, but it could quite easily be fine.
    • We had this blend that uses 98RON + 10% Ethanol which brought it to 100RON. It's no longer available anymore unfortunately.
    • Does it make a difference in your turbo having a shorter life if you have a cat converter as it causes that back pressure versus less/no back pressure with a decat? (Not sure if this is accurate) Also slightly different question if you went from a oem cat to a decat or vice versa will it require a tune? I heard if you change the dump pipe onwards it requires a tune?
    • No. Have only gotten as far as contemplating the task of having to put in the required fairly heavy wiring and fusing to run it (along with the big alternator), and preferring not to. But otherwise, it would be nice to have a little extra freedom as to exactly where the compressor is located and free up some space around the exhaust side of the engine.
    • Following from this in a related by not closely-related sense... Because I was buying a bunch of other GKTech stuff, I got some rear subframe collars. The history that leads up to this is: 25+ years ago the car arrived into the country with stock subframe bushes. At some point shortly thereafter I added Whiteline pineapple rings, set up neutral, and it improved the rear end behaviour. Well, it is my vague memory that I was happier with it with them in. Less axle tramp on launches, generally better, etc etc. ~2012 it got a new non-HICAS subframe with new stock bushes. No pineapple rings. I reckon that ever since then I've been dissatisfied with the axle tramp. Recently I've been f**king around a lot with all aspects of the suspension. One contemplation has been to relocate the rear lower control arm front mount points (and do the other things needed to make that work) to improve longitudinal rear grip by getting rid of some of the stupid anti-squat that Nissan ladled into the R32. But.... before doing that I thought I'd put some collars in. And.... The collars are good. The rear sounds a little bit different, but there has been no significant increase in NVH coming up into the body. In terms of rear behaviour - expansion joints on long sweeping elevated freeway ramps that would sometimes cause the rear to jiggle around a bit, no longer seem to do so. It appears that jamming chunks of metal into the gaps in the rubber so they can't move much is a really good thing. And the launch behaviour and general forward traction situation seems to be greatly improved too. It's impossible to be really sure, because the tyres are completely shagged - they are freakishly willing to let go right now. But as an A-B test with the same tyres it certainly seems to grip up a lot better. Highly recommended to anyone who still has stock bushes.
