wow that parts list is impressive Mark - can't wait to see what it makes tuned! I am guessing around 350rwkw?
was thinking to myself who the f is mark :) right Jenkies has a first name he got 1 of those 2 :ninja:
they gota go on the car before it makes that :blink: hurry up all ready man
Edited by Inline 6
ummm good question luke, i cant really remember, pretty sure mine still uses the normal brake lines. Matty can probly verify whats needed when he jumps on here next too.
hahah hoping for 300-320 awkw on 16 pound with a nice thick mid range..... exciting times!
Has anyone fitted s13 coilovers to the front of a R31 wagon? if so what needs doing?
cheers
i have mate
you need, s13 hub and nuckles, stub axel, calipers and rotors, s13 tie rod ends....
if you want a hand let me know.
Edited by Ryanrb25
thanks mate, its for my mate. he has s15 front coilovers and wants to chuck them in his wagon. Will let u know if we need a hand.
btw found this http://page.auctions.yahoo.co.jp/jp/auction/111069170 :ninja:
around 15k just for the motor before shipping.
The S15 Struts have a 14mm bolt the holds them to the hub and the S13 has a 12mm hole so you will have to get the uprights on the hub redrilled to 14mm to use them with S15 struts.
EDIT!!
I think it's actually around $1600 not $15,000.
Currency Conversion Results
Symbol Japanese Yen Exchange
Rate Australian Dollar Bid Ask
JPYAUD=X 150000 Sep 24 0.01123 1,684.84901 0.01123 0.01124
Edited by D_Stirls
soooooo f**ked up right now...
OMG DEVILDRIVER!!!!!!!!!!!!!!!!!!!!!!
im going!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
when/how do i get tix?
uhm... dont really know eh.
soundwave sounds awesome
BILLY TALENT FACE TO FACE NEW FOUND GLORY GOLDFINGER
thats enough to convince me :)
new found glory, alkaline trio, and 36 crazyfists are all it took to convince me. :D
i saw devildriver when they came here for gigantour with megadeath, static x and lacona coil
they werent as good as what i thought they were going to be but they did get a good mosh going!
tha some hot polish sausage!!
I got some really hot smallgoods at home, like spicy cabana!
You should try some chilli sauce I got at home :dry: Its rated 10+/10 = nuclear grade chilli :/
    • Um. No. Since Matt introduced the TIM it has become a lot easier to deal with the consequences of changing K for AFM and injector swaps. Then, tuning is a f**king doddle. No-one needs to know or care how many grams of air are flowing or any other bullshit. Need more fuel in a cell? Add more fuel. Need more timing in a cell. Add more timing. Need to adjust any of the other tables for warm up and so on? No harder than anything else. Sure - it's not an ECU system for starting from scratch on an arbitrary engine. But then.....it was never supposed to be, not recommended for, and almost never used that way. So.... On your engine, in particular, Nistune/Nissan OEM is about as sophisticated and difficult as banging 2 rocks together. Those ECUs are primitive and simple. There is nothing difficult there. I learnt Nistune from scratch, created new maps with extended axes, interpolated/extrapolated the original maps onto them and tuned my RB20 (basically the same ECU as your 26 ECU) all by myself, more than 20 years ago. And that was long before even TIM.
    • Set of knee pads for a R34. Will fit every model I think. Comes with everything except the rubber covers for the bolt holes. Still in great condition. You will need to drill holes to mount these or use double sided tape. I can do free shipping and will be shipping from the Netherlands with tracking.
    • Nistune needs something like an entire excel spreadsheet in which you build an abstraction layer that converts everything from real units you can actually measure into all of the various tables. The number of unexpected dependencies hiding in how the Nissan ECUs do math is a pretty impressive optimization trick for 8-bit MCUs but good god is it awful to actually work with in practice.
