if its michael doing it, you will be sweet :P
thats the next big shop imho
aussie dyno = top work.
its actually Peter that does it Craig, Michael just sits in the passenger seat and holds the pfc controller...lol
+1 for Aussie dyno
well i think im gonna run
17x9.5+17 front
18x10+18 rears
or stick to the 18x9 +20 fronts!?
good choice my friend....will be good!
+1 for Aussie dyno
Michael is actually tuning the car dan, pete is just running the car up.
Edited by Ryanrb25
+1 for Aussie dyno
where are they located??? i reckon i need to switch workshops as the current one i take my 32 is not that crash hot and now thinking of things they have done im getting pissed off lol
would take it to boostworx but it is too far out the way for me.
cheers
i was in melb from friday and got back tonight :banana:
just HAD to take the 33 out for a drive after leaving it sit for 3 days :angry:
so glad im home now , got so bored at grandparents house :bunny:
we got into Melbourne at hmm 10pm (Vic time).
yeah we left our car parked at the Crown Casino the whole time, too much walking
back and forth, but it was great.
on the way back from parking the car me and my mum walked past 2 guys, 1 said
"what do i do?" and the other guy said "well what you do is ask how they are and how there
night is"
i friggin pissed myself laughing coz well practicing what to say to a girl to pick her up :nyaanyaa:
i miss Melbourne :rant:, i didn't get homesick so yay
well got all the turbo and all piing etc put back on, gave it a quick start
to make sure it still runs :banana:
only thing i noticed is a big amount of smoke :nyaanyaa:
hope its just cos it hasnt been started in ages.....
gotta tighten up all the cooler pipes and final bits ' n peieces, add some coolant
and it shouls be done...... i hope.
all this for one bloody gasket.
Has anyone done pads on the rear with only 2 of the halves having metal tangs in the corner of the pad while the other 2 halves don't?
Anyone knows if it matters whether the pad with the tang goes on the inside or outside of the rotor?
Sample pic only, off a different make of vehicle;
ahh good stuff Luke thanks....I better get back out there and finish off now.
Doing the rear coilovers tonight as well and the fronts tomorrow hopefully.....will post up pics later.
EDIT: Just looked at your pic Luke, that looks more like an anti-squeal shim that goes across the back of the pad......is that what you were referring to or were you talking about the small tang on the bottom corner of the pad?
The tab is just the wear indicator. As 4 piston calipers should wear evenly (equal pressure on both sides and no sliding pins that lock up) it doesn't really matter where it goes.
It's the thing that squeals so you know that your pads are close to worn out before they actually are and you have metal to metal contact
Edited by D_Stirls
    • I wouldn't be concerned at all, other than to suggest having them flow tested when you receive them to confirm they are reasonably similar, and then put the highest to lowest flowing ones in cylinder 6,1,5,2,4,3
    • I’m only posting this cause I thought I had seen a bad review on these somewhere before. Any feedback? Would you guys recommend that if I do buy these I send em to RC to have em checked before installing. Or any other suggestions?   https://www.ebay.com/itm/114009965865?mkcid=16&mkevt=1&mkrid=711-127632-2357-0&ssspo=JDl-15yLQ8C&sssrc=4429486&ssuid=QTzlFXB1S-S&var=&widget_ver=artemis&media=COPY
    • They see me rollin' they hatin'....... Took me most of the day to make the necessary mods to the mounts to make them fit the car.  Fortunately I was able to just use the mounts that came with the rotisserie. The rear ones are really secure, the front I feel i might reinforce a bit more as it doesn't seem like enough attachment to the vehicle. I'm sure it's fine but better to be safe than (extremely...) sorry.  I drilled and tapped thread into additional M12 holes to each car mount where it attaches to the rotisserie as an extra fail-safe. Without them the side to side movement is just restricted by the allen head pinch bolts, nothing actually goes though the beam. Does now! I still need to adjust the rotisserie to get the car centred in terms of centre of gravity. If it's too high or too low relative to the rotational centre line of the car, it will be like a turtle and roll onto its back or as it currently sits, I dont think I'd be able to rotate it as it sits as it needs to lift the whole car up as it rotates. Ain't happening... I'm going to be nervous as hell the first time I go to spin it on its side...
    • Oh yes done this when the window started flopping around.  Turns out the guides that run along the rail chanel had crumbed way. Took off the door card and pulled out the window mech, then the window, which you have to pull out through the top. As said unbolt the guide rail and don't spend 30 minutes getting frustrated trying to find a way to slide it out upwards cause that don't frigging work. Drop it down and out through the door hole. All I did to repair it was slice some 10mm clear plastic tube, vertically, then screw it to the guide rail both sides. This tubing rolls inward on both sides and leaves a gap wide enough to hold the window. To finish all I did was lube the plastic tube with olive oil and Bob's your uncle . . . well if he has the operation he can be your Aunt ! !  10 bucks in plastic tube and another 5 minute job done again . . . . YEH BULLSH#T ! My love for Skylines knows no bounds !
    • So was there a solution to this problem? I’m having this issue now.
