The Sa Wasteland
Cubes
 Share
if its michael doing it, you will be sweet :P
thats the next big shop imho
aussie dyno = top work.
its actually Peter that does it Craig, Michael just sits in the passenger seat and holds the pfc controller...lol
+1 for Aussie dyno
well i think im gonna run
17x9.5+17 front
18x10+18 rears
or stick to the 18x9 +20 fronts!?
good choice my friend....will be good!
+1 for Aussie dyno
Michael is actually tuning the car dan, pete is just running the car up.
Edited by Ryanrb25
+1 for Aussie dyno
where are they located??? i reckon i need to switch workshops as the current one i take my 32 is not that crash hot and now thinking of things they have done im getting pissed off lol
would take it to boostworx but it is too far out the way for me.
cheers
i was in melb from friday and got back tonight :banana:
just HAD to take the 33 out for a drive after leaving it sit for 3 days :angry:
so glad im home now , got so bored at grandparents house :bunny:
we got into Melbourne at hmm 10pm (Vic time).
yeah we left our car parked at the Crown Casino the whole time, too much walking
back and forth, but it was great.
on the way back from parking the car me and my mum walked past 2 guys, 1 said
"what do i do?" and the other guy said "well what you do is ask how they are and how there
night is"
i friggin pissed myself laughing coz well practicing what to say to a girl to pick her up :nyaanyaa:
i miss Melbourne :rant:, i didn't get homesick so yay
well got all the turbo and all piing etc put back on, gave it a quick start
to make sure it still runs :banana:
only thing i noticed is a big amount of smoke :nyaanyaa:
hope its just cos it hasnt been started in ages.....
gotta tighten up all the cooler pipes and final bits ' n peieces, add some coolant
and it shouls be done...... i hope.
all this for one bloody gasket.
Has anyone done pads on the rear with only 2 of the halves having metal tangs in the corner of the pad while the other 2 halves don't?
Anyone knows if it matters whether the pad with the tang goes on the inside or outside of the rotor?
Sample pic only, off a different make of vehicle;
ahh good stuff Luke thanks....I better get back out there and finish off now.
Doing the rear coilovers tonight as well and the fronts tomorrow hopefully.....will post up pics later.
EDIT: Just looked at your pic Luke, that looks more like an anti-squeal shim that goes across the back of the pad......is that what you were referring to or were you talking about the small tang on the bottom corner of the pad?
The tab is just the wear indicator. As 4 piston calipers should wear evenly (equal pressure on both sides and no sliding pins that lock up) it doesn't really matter where it goes.
It's the thing that squeals so you know that your pads are close to worn out before they actually are and you have metal to metal contact
Edited by D_Stirls
 Share
    • There is a LOT of stuff that can be done, it all depends on how much time and money you want to spend on doing in.  Not all ECUs will be able to do it, and the more control you need the more time and knowledge needs to be put into making it work.  If you're willing to spend the time and money and have the right hardware and skills involved there's a lot that can be done.
    • I am impressed with all this level of adjustment. I didn't expect all this possibility
    • Correct.  In the case of the 500kw dyno plot I showed you the car actually runs two boost control solenoids for boost control and a 5psi wastegate spring.  It allows me to control how much boost pressure is applied to both sides of the wastegate valve at any point and fairly accurately control boost target as a result. I've tuned it so that it's able to target anywhere from 5psi to 25psi depending on what's needed.  The target tables I've set up in that car are Gear vs RPM, so every gear has potential for a different boost (and torque) curve.   First and second gear have quite low boost targets, third gear actually has different target boost all the way through the rpm range as it's a stock RB25 gearbox - the boost targets have been chosen to maintain a peak of 600nm (what the owner has set as the maximum torque he's happy with putting through the stock 3rd gear) but it carries that to the rev limiter.   The boost curve to achieve that is something of a ramp up, then hold, then ramp up again and the power curve looks more like a flat line haha.
    • so you can decrease or increase the boost depending on the diet as you wish?     by acting on the wastegate?
    • That's torque and power, it's all from a single run.  The boost curve is "held back" from it's peak target in the 3500rpm to 5000rpm range from memory, so it ramps hard to something like 18psi then climbs more progressively to 23psi nearer 5000rpm.   It makes the torque (and power) ramp more "natural" and less hard on parts and traction, it doesn't feel artificially held back.
