ahh good stuff Luke thanks....I better get back out there and finish off now.
Doing the rear coilovers tonight as well and the fronts tomorrow hopefully.....will post up pics later.
EDIT: Just looked at your pic Luke, that looks more like an anti-squeal shim that goes across the back of the pad......is that what you were referring to or were you talking about the small tang on the bottom corner of the pad?
the little small metal thing that hangs out bellow the caliper is what im trying to show.
Was that all you need?
did anyone else turn the aus top gear off before it finished?
i thought it sucked and the people they got to host the show were crap :D
i actually didn't mind it the track they used and camera angles were crap but on the whole the show wasn't to bad of a rip
one of my all time favourites.
I was looking for one for ages. never found a clean enough example for sale.
I ought to stop browsing carsales it keeps tempting me to sell up, but the thought of selling up is too heartbreaking! lol
The tab is just the wear indicator. As 4 piston calipers should wear evenly (equal pressure on both sides and no sliding pins that lock up) it doesn't really matter where it goes.
It's the thing that squeals so you know that your pads are close to worn out before they actually are and you have metal to metal contact
Yeah all good now, thanks boys.
I want 350kw :D
Well Chad, you better hurry up and find someone to do a turbo upgrade for both of us if you want that sort of power :D
oh pete, i owe you a drink too. The drinks i had at mine werent for my bday, was just a random event lol. mY bday isnt till later in the year. Cheers though and my round next time :D
today : shittest day of my life so far
had an job interview lined up for 10:45am , get a message 10 minutes ago saying " interview has been canceled , boss is looking for more experienced people"
how am i meant to get this frigging "experience" if i cant get a job in the frigging area that im applying for ffs -_______-
drive more :miner: !
Hmm ...
Collected from importers in Sydney ... had 32,000kms on the clock then ... drove it back to Adelaide!
Drove it to Wagga Wagga and Canberra and back to Adelaide a month or so ago.
Driven to work every day and cruises on weekends.
Driving it this Thursday to the Phillip Island MotoGP for the weekend.
I'm racking up the mileage ... how about you? :P
    • Yes...but look at the numbers. There is a tiny tiny fraction of the number of Joules available, compared to what is used/needed. Just because things are "possible" doesn't make them meaningful.
    • Thanks for taking the time to post that ! If anything changes or happens please do update us.
    • Somehow Vertimass/Oak Ridge National Labs has figured out a catalyst that can convert ethanol into C9-C10 hydrocarbons in basically a single step without ending up with a bunch of ethylene or similar waste products: https://patents.google.com/patent/WO2023224867A1/en I still don't think anything like this will keep us from needing to transition to EVs regardless along with all kinds of other electrification, but things like this will go a long way towards alleviating the problem of how to electrify things like planes. Renewable diesel is seemingly an easier problem as well, Chevron is already running refineries for the stuff and the primary feedstock is tallow and other waste fats from agriculture.
    • Ok so I have sorted everything with my uniclutch and  i can offer up a bit of feedback and some things that might help others.    I found problems with factory damper line. Weird shit and had trouble with peddle adjustment    I used this https://au.gktech.com/products/r33-gts-t-skyline-braided-clutch-line?_pos=2&_sid=22b01b9b9&_ss=r Also when adjusting peddle leave a bit of play. You can get into a over stroke condition easy.. Make sure you can push the slave forward after adjusting to confirm fluid can return to master then you will need to pump it up heaps…..not sure why but that’s how it is.    last thing the splined adapter is machined perfectly. If your input shaft is old like mine was I would put a bit of valve grinding paste on it and stroke it like a 15 year old. Just to give it a tad more clearance and to better match it to the spline.    reason is on a near flat shift I have had situation where the peddle returns a millisecond after you lift from the clutch. No slip or anything but I reckon this is due to tolerance on the spline being way tighter than stock clutch and binding for a sec. I think this will go away but also my spline was old. Box is old so I guess I should have checked better. It’s a super neat fit.    it feels light as and holds awesome without any noise
    • My Fuga Hybrid is JDM, 2014 model but very similar to the V37 from the looks of things..same platform just physically larger and very comfortab;e
