The Sa Wasteland
Cubes
 Share
ahh good stuff Luke thanks....I better get back out there and finish off now.
Doing the rear coilovers tonight as well and the fronts tomorrow hopefully.....will post up pics later.
EDIT: Just looked at your pic Luke, that looks more like an anti-squeal shim that goes across the back of the pad......is that what you were referring to or were you talking about the small tang on the bottom corner of the pad?
the little small metal thing that hangs out bellow the caliper is what im trying to show.
Was that all you need?
did anyone else turn the aus top gear off before it finished?
i thought it sucked and the people they got to host the show were crap :D
i actually didn't mind it the track they used and camera angles were crap but on the whole the show wasn't to bad of a rip
one of my all time favourites.
I was looking for one for ages. never found a clean enough example for sale.
I ought to stop browsing carsales it keeps tempting me to sell up, but the thought of selling up is too heartbreaking! lol
The tab is just the wear indicator. As 4 piston calipers should wear evenly (equal pressure on both sides and no sliding pins that lock up) it doesn't really matter where it goes.
It's the thing that squeals so you know that your pads are close to worn out before they actually are and you have metal to metal contact
Yeah all good now, thanks boys.
I want 350kw :D
Well Chad, you better hurry up and find someone to do a turbo upgrade for both of us if you want that sort of power :D
today : shittest day of my life so far
had an job interview lined up for 10:45am , get a message 10 minutes ago saying " interview has been canceled , boss is looking for more experienced people"
how am i meant to get this frigging "experience" if i cant get a job in the frigging area that im applying for ffs -_______-
drive more :miner: !
Hmm ...
Collected from importers in Sydney ... had 32,000kms on the clock then ... drove it back to Adelaide!
Drove it to Wagga Wagga and Canberra and back to Adelaide a month or so ago.
Driven to work every day and cruises on weekends.
Driving it this Thursday to the Phillip Island MotoGP for the weekend.
I'm racking up the mileage ... how about you? :P
 Share
    • Because there is still an engine underneath that turbo. PSI is not a measurement of power, it's a byproduct of resistance. What would be really decent is to have a CFM gauge on the output of a turbo to see how much it's actually pushing. 21psi (as an example) is not the same amount of air at 3000rpm as it is at 7000rpm, even if the boost controller is controlling boost at "21psi". The engine is inhaling and exhaling way more air at 7000 than at 3000, even if it's less efficient.
    • don't want anything more or less, I don't really understand why the torque still goes up to 6000-6500, while the boost peak is around 4000. if it only comes from the cams or from the boost controller etc.
    • I'm not sure you understand the physics of what you are asking. Can you draw on the dyno graph what you want to have happen? I'm thinking this is a functional impossibility here, unless you chose a turbo literally so laggy that torque is at max at 7000rpm and artificially choked prior to that. Power and Torque are intrinsically linked. Power is just Torque over time. What you're really seeing in the torque graph is "Power per RPM" if that makes any sense whatsoever. You still get more power at 7000rpm than 5000rpm, because it is "power per RPM" and you have more RPM. at 7000 than you do at 5000. You still feel more powerful at 7000rpm. The torque graph will influence the rate of power increase per RPM.
    • Welcome!  If possible,  would live to see some pics. How long was it away getting the work done? Hopefully it feels like a new machine.
    • yes indeed the graphic format makes a visual difference but there is on average 120nm more between 4000 and 6000rpm on the curves it is not nothing. you are right, the cams influence the torque curve. I was able to chat with one of the Hypergear tuners, he confirmed that a boost control allows you to manage the pressure after the spool. the absolute pressure (psi) on the graphics is measured where? It seems that the cams affect the maximum pressure depending on the regime but I may be wrong.   not pleasant to drive before 4000? if we spend our lives between 1000 and 3000 rpm as you say then we might as well just run diesel turbos
