The Sa Wasteland
Cubes
 Share
mates 180 is written off because of some stupid f**king wog parking in a no standing zone and 1m from the curb and because the 2 cars in front hit the breaks
not too happy
your mate was too close to stop = fail
A rear ender like that is usually open and shut, 100%, tailenders fault.
Hope your all OK and no-one was hurt.
i think ive busted my shoulder up , gonna go get it checked out tomorrow
my mates devastated cause he just got the car with a loan and now it seems to be written off
sure its not my car but im on the verge of tears cause it brought back memories from a major car accident i was in a few years back :P
+1
hope u guise are all ok
i dont really trust anyone on the roads, fkt if i sit any closer than 3 car lengths behind ppl. been a passenger in similar situation, with a mate who is a hero that can drive close to ppl
thanks
+1
i sit atleast 4 cars away from the car in front , we just came off the lights and then it happened :)
looks like me n my mate will be turning it into a sil80 now :P
thanks
yeah, i just consider everyone else on the road is a tard.
hope ur aches n pains arent too bad when u wake up in the morning.
on the plus side...... u guise have a new project :)
we had a project before we went to get kfc
replace the Y fork in his transmission :D
got the part on hold at nisswreck but im guessing we will be haulin s13 parts around now :)
were also going to order coilovers , bucket seat , sway bars , strut braces , caster rods and brake cylinder stoppers for both of our cars but im sure thats on hold now :(
oh well , life goes on , cars are repairable
end of the day , too many tards on the road :P
yeah sure. whenever i need to take them off again or free one weekend i'll let u know.
btw kye they look tough. Just need those coilovers now.
Edited by Luke_ENR34
haha yeah tell me about it. its pretty dumped but just needs another inch or so to set it right off.
ill be bottoming out on small pebbles by the time i get it low enough :P
abit mexican at the front though! going to run smaller tyers and more camber i think
 Share
    • There's probably an underlying issue with the A/C system too. I recently fixed mine, now it's fully control by the Haltech and car's factory HVAC controller  Have a squiz here:
    • And by the way, I've also checked the ECU diagnostic numerous times and got a bad O2 sensor code and initially an Ignition Primary code, which is why I replaced the O2 sensor and all the ignition components (coil packa, plug and loom). No codes have been coming up lately despite the ongoing issue.
    • Hey pber13, unfortunately still no luck. At this point the following has been done with little or no success: - Spark plugs replaced, gapped to 0.8mm - Splitfire coilpacks installed to replace originals - Replaced Ignition Coil/Coilpack harness with a new genuine nissan one - New fuel filter - Replaced AFM/MAF sensor - Injectors have been thoroughly cleaned with an online flush (without removing) - Upper engine and inlet decarbed - blew tons of black smoke out, cleared the carbon deposits from the top of the engine and exhaust.  - IACV removed and thoroughly cleaned with carburettor cleaner - O2 sensor replaced with new and genuine one -  Smoke test revealed no vacuum leaks - Healthy compression test of 160psi across all 6 cylinders Overall the car does run a lot smoother now, no backfires between gear shifts like it did originally... but the rough idle when warmed up is still there. It may not even be a misfire but simply a rough idle. Seems crazy to me that so many people have had this issue and seemingly no one has gotten to the bottom of it, or at least never bothered to post if they did! Hope you have more luck than I did pber13, I'm at a point now where I'm just going to try to ignore it unless it gets worse. Would love to fix it but I've genuinely run out of ideas of what it could be.
    • I got the full frenchys kit too. Really awesome kit. Easy to install my only complaint was the hardlines I think could be routed differently (I modified mine) but I realise the kit needs to suit multiple applications. This was the hard lines before I modified them. They were touching the wastegate pipe. I ended up reducing the distance between firewall and first bend. The made it so they tucked along the frame rail.
    • Deeve, I don't suppose that you've made any progress on this? My Stagea has the exact same problem, and just like you, I've read through as much as I can online, with no real progress. My car isn't throwing any codes at all, which is a little frustrating. I've changed plugs, checked the wiring and harness. A new MAF gets here next week, but I'm not hopeful it will solve the issue.
