they are 17x 8 +17 fronts and 17x 9.5 +24 rear :dry:
Are they Brentons old meshies? Specs sound similar. Look like they sit pretty mint, full body shots needed (in daylight) though :kiss:
i just went down the street to get drinks for tomorrow, and had a guy come up and introduce himself to me.
it was none other then Mr Senwill himself, he liked my car!(and i liked his, brand new twin turbo range rover, he also has a brand new single turbo petrol one.. :P )
had a chat with him about a bit of stuff, then he gave me a Drift Central 3 dvd! put a smile on my face to meet someone like that in a little town like this, AND he was the nicest dude you will ever meet!
stoked!
Random as
Edited by AndrewJZX100
Well a massive thanks to Ryan, Aussie Dyno and Turbosmart for seeing my car pull 198.1 rwkw today :( apparently im a bashed cat away from 220. ill post up my dyno sheet once i get my camera working. Highly recommend Aussie Dyno, made very very sure i was running 100% safe while still squeezing power out of it!
oh yeah, the hoodies wont be at vili's tonight, due top lack of interest combined with my family down from interstate. next pick up will be my cruise on monday
Edited by Damo_R34
hey mods... can we get aussie dyno into the workshop listings?
Aussie Dyno Mufflers & Brakes Pty Ltd
(08) 8340 0584
373 Port Rd
Hindmarsh SA 5007
exhausts, tuning, dyno (4wd), general mechanics.
cheers
hey guys, after an opinion!
under boost, my 25 is making a high pitched squeel - from area around the turbo; i'm thinking it may be exhaust/manifold leakage.
I havent really investigated by removing bits and pieces under the bonnet yet, - i might take the heat shield off the std turbo tomorrow and have a geeze for any signs of soot and black crap.
Anyone had this issue before?
yes mate i had this exact same problem about a month ago, gasket between turbo and manifold mate...
ahh, so it very well may be the culprit! I asked my usual mechanic, and he guessed that a gasket would probably be the cause.
so basically, you got to remove exhaust front pipe and dump, remove turbo, replace gasket + new studs yeah?
doesnt sound like much, but it'd be a pretty legnthy job hey Ryan?
    • The fuel pump bracket just slides straight up.  Below is a pic I stole off a site. But basically put hand in for fuel pump, wiggle it all about a bit while pulling up.
    • Went digging Duncan, there's another "item" that sits down under the plenum that the second pipe from the IACV goes down to. I believe that's the one that is apart of the cold start portion, and it then comes back up under the middle of the factory top plenum. I believe you will find it is unneeded on the forward facing plenum on Cheryl.   I just went digging further for some pics on the location of the one way check valve, and found something that confirms my thoughts from the first half of this point. I feel you can just block off that port that is coming down.     I can also confirm, the other line that you were thinking for vacuum that will just need a one way valve put into Cheryl is 100% correct too. The one way valve is normally screwed into the back of the factory inlet plenum.
    • You’re an absolute legend man. Cheers.
    • The rule of thumb for any GTR thats doing a single turbo conversion is..... seqy... and when i say seqy, i dont mean the pos PPG either. *flamesuit on*
    • The ECU does care - it runs the engine as two banks of 3 wrt O2 trimming. So you have to give it the right one. Um....look at the engine bay pictures in the GTR manual? I think you can make them out there. I think the physical wiring diagram might also help.... Actually, I just looked at the engine bay wiring diag. It clear shows the shapes of the connectors. I'd say that R means rear. According to the rest of that diagram, pin 2 of the R one turns up at terminal 55 of the ECU. Which is.....the rear one.
