they are 17x 8 +17 fronts and 17x 9.5 +24 rear :dry:
Are they Brentons old meshies? Specs sound similar. Look like they sit pretty mint, full body shots needed (in daylight) though :kiss:
i just went down the street to get drinks for tomorrow, and had a guy come up and introduce himself to me.
it was none other then Mr Senwill himself, he liked my car!(and i liked his, brand new twin turbo range rover, he also has a brand new single turbo petrol one.. :P )
had a chat with him about a bit of stuff, then he gave me a Drift Central 3 dvd! put a smile on my face to meet someone like that in a little town like this, AND he was the nicest dude you will ever meet!
stoked!
Random as
Edited by AndrewJZX100
Well a massive thanks to Ryan, Aussie Dyno and Turbosmart for seeing my car pull 198.1 rwkw today :( apparently im a bashed cat away from 220. ill post up my dyno sheet once i get my camera working. Highly recommend Aussie Dyno, made very very sure i was running 100% safe while still squeezing power out of it!
oh yeah, the hoodies wont be at vili's tonight, due top lack of interest combined with my family down from interstate. next pick up will be my cruise on monday
Edited by Damo_R34
hey mods... can we get aussie dyno into the workshop listings?
Aussie Dyno Mufflers & Brakes Pty Ltd
(08) 8340 0584
373 Port Rd
Hindmarsh SA 5007
exhausts, tuning, dyno (4wd), general mechanics.
cheers
hey guys, after an opinion!
under boost, my 25 is making a high pitched squeel - from area around the turbo; i'm thinking it may be exhaust/manifold leakage.
I havent really investigated by removing bits and pieces under the bonnet yet, - i might take the heat shield off the std turbo tomorrow and have a geeze for any signs of soot and black crap.
Anyone had this issue before?
yes mate i had this exact same problem about a month ago, gasket between turbo and manifold mate...
ahh, so it very well may be the culprit! I asked my usual mechanic, and he guessed that a gasket would probably be the cause.
so basically, you got to remove exhaust front pipe and dump, remove turbo, replace gasket + new studs yeah?
doesnt sound like much, but it'd be a pretty legnthy job hey Ryan?
    • to fix the voltage drop issue I swapped out the old 150amp alternator which turns out is a brand known for having issues and replaced it with the black 180amp alternator beside it
    • For anyone interested, the Way Back Machine has that Japanese website archived with pictures, etc: https://web.archive.org/web/20051023225805fw_/http://www.a31cefiro.com/air_con.htm "Simply swapping the wiring of the harness will not allow it to function properly. For the outdoor air sensor and sunlight sensor, disconnect the wiring connected to CN1-11 of the air conditioning harness from the harness and connect the sensor side wiring to earth. For the indoor air sensor, disconnect the wiring connected to CN2-3 of the air conditioning harness from the harness and connect the sensor side wiring to earth. The connector PIN numbers listed here are the genuine A31 PIN numbers. To avoid incorrect wiring, check with a tester before wiring. Also, disconnect the wiring in a location close to the sensor. The disconnected harness side wiring will not be used, so be sure to insulate it." Wish someone sold a conversion harness to just plug-and-play a Kouki 180sx digital climate control into C33/A31. I'm decent with wiring but feeling kinda lazy about taking this on. Edit: Did some more digging and found a helpful Minkara blog post about the conversion as well: https://minkara.carview.co.jp/userid/1831116/car/1360568/2284209/note.aspx "After installation is complete or the battery is replaced, you need to go into self-diagnosis mode and set the internal air recirculation. The way to do it is to "hold OFF with the key on for more than 5 seconds, set the number to 5, then press 卍→C." ↑↑↑It probably won't make sense unless you actually try it (・∀・)." Lol wtf
    • Maybe SAUNSW could see howany members would do a motorkhana day if Schofield's is still available for a reasonable price...
    • Skip the concrete, we just need to smooth a field. Mark knows how to drive a grader Duncan   I reckon 100x100 flat area for skid pan style, and then some sort tracks for rally... Duncan's already got a rally car on the premises to...
    • Well, yeah, the RB26 is definitely that far off the mark. From a pure technology point of view it is closer to the engines of the 60s than it is to the engines of the last 10 years. There is absolutely nothing special about an RB26 that wasn't present in engines going all the way back to the 60s, except probably the four valve head. The bottom end is just bog standard Japanese stuff. The head is nothing special. Celicas in the 70s were the same thing, in 4cyl 2 valve form. The ITBs are nothing special when you consider that the same Celicas had twin Solexes on them, and so had throttle plates in the exact same place. There's no variable valve timing, no variable inlet manifold, which even other RBs had either before the 26 came out or shortly afterward. The ECU is pretty rude and crude. The only things it has going for it are that the physical structure was pretty bloody tough for a mass produced engine, the twin-turbos and ITBs made for a bit of uniqueness against the competition (and even Toyota were ahead on the twin turbs thing, weren't they?) and the electronic controls and measuring devices (ie, AFMs, CAS, etc) were good enough to make it run well. Oh, and it sounds better than almost anything else, ever. The VR38 is absolutely halfway between the RB generation and the current generation, so it definitely has a massive increase in the sophistication of the electronics, allowing for a lot more dynamic optimisation of mapping. Then there's things like metal treatments and other coatings on things, adoption of variable cam stuff, and a bunch of other little improvements that mean it has to be a better thing than the RB26. But I otherwise agree with you that it is approximately the same thing as a 26. But, skip forward another 10 years from that engine and then the things that I mentioned in previous post come out to play. High compression, massively sophisticated computers, direct injection, clever measuring sensors, etc etc. They are the real difference between trying to make big power with a 26 and trying to make big power with a S/B50/54 (or whatever the preferred BMW engine of the week is).
