The Sa Wasteland
Cubes
 Share
Eddy rules Joel :wacko:
That sounds so bad if you were referring to me....good thing it was obvious you weren't.
Ryan: Cheers for the offer, I know your a busy man so let me know when you're free and we can sort something out.
lol ryan,do we wanna know how you know how to do that :wacko: lol
eddy, ryan pretty much knows everything about everything most times so more than likely he will be able to figure it out. Hopefully its something small.
there could be so many police out today coz it's the SANFL grand final today
coming home from town today a heap of cops flew down south road and by heaps... 5 bikes, 5 patrols, 2 detectives and a paddy wagon
anyone know what happened?
Nope, that being said, I've been at work so I haven't had a chance to try and fix it today.
Nothing. I have to use the key to get in because the central locking isn't going (The remote is fine), then when I turn the key in the ignition nothing happens. I've checked the battery and connections and that's fine and so are the fuses so either it's either the starter motor or the immobilizer screwing up.
Are you saying no electrics work?
An immobiliser may effect your central locking (but i wouldn't have thought so) but if you have no other electrics in the car I doubt its the immobiliser and certainly not the starter motor.
Can you get your alarm to activate? interior light or headlights to work? hazard warning lights? (an immobiliser shouldn't stop all of these from working and will indicate the problem is instead between the battery and the fuse box)
You said you checked out the battery - but it might be worth trying another one if you have one handy, or try a jump-start.
I would also be checking the battery terminals (you wouldn't be the first to have corrosion in the terminal cause a problem like this)
Not sure if the 32 has a fuse in the main battery line (some cars do) or a big spade fitting that has corroded (took me a while to find this problem on an old valiant once)
 Share
    • Much less twat-tastic. CF wheels are too garish for civilised use.
    • From there, as the manual says....assembly is the reverse of disassembly, no tricks worth mentioning Much better (for me)
    • In my case, the standard wheel I had was in good condition but the buttons had more wear, so I swapped them across from the original wheel from the car. The plastic rear cover is held on by 4 tabs, and once the wiring is removed you can get access to 2 screws on each side the hold the buttons in From there I just swapped the wiring over. What was interesting is the standard style wheel is 2.0kg but the carbon fibre one is 50% heavier at 2.9kg. It even has a weight inside the wheel at the top to make up for some sort of imbalance in the design. weird
    • Once the airbag is off, to remove the steering wheel.... Undo the 2 plugs into the clock spring, and the horn connector from it's clip. Hit the 19mm nut with a rattle gun (preferably) or if you don't' have one, you probably want an assistant to hold the wheel in place while you use a breaker bar to undo the nut Then, screw the nut back on 3 turns, and pull the wheel sharply towards you. If that doesn't work hit it medium force with a rubber mallet on either side, or possible behind if you can get there. If that all fails (it shouldn't!) you might need a steering wheel puller
    • So, to next task....the carbon fibre steering wheel was either an expensive factory option or a chinesium special. Either way, I don't like either the flat bottom or thick ring style, so it had to go So...to remove the steering wheel.... First, disconnect battery negative and stomp on the brake pedal for a few seconds. Then, remove the small circular covers on each side of the wheel's rear surround to uncover the airbag clips. You need to push something like a flat bladed screw driver through, to push the steel clip inwards and pull the side of the airbag forward. Once you've done the easy side, same on the centre console side. You can see the tab you are shooting for circled in red Then, disconnect the horn spade connector and for the yellow airbag plug you need to get something small under the black locking tab to pop it out, then the connector releases......airbag is off
