The Sa Wasteland
Cubes
 Share
they do make 32 shells ive seen themm they fit a bit tight on the drift rc's though wheels hang out a bit outa the guards but who's wheels dont :blink:
i seen it at the hobby habit where they do the rc drifts. comes in GTR style only but the wing is seperate so easy enough to make it look more like yours.
kye has 1 of his own car.
also while im hear could mods please change rad32's name to
RAD MOBILE :) come on everyone agrees
Edited by Inline 6
im also keen for different work. Been at current job for 4 years, think its time for a change. DOnt wanna go earn less money though, so if anyone knows o a decent job going at over $19/hr let me know :(
pitty they dont make 32's!!!! :(
HPI make them, iv got the r32 gtr and r34gtt shell both are 200mm bodys so they will fit any 1/10th scale also yokomo make light brackets for the r34 so you can run L.E.Ds (D1 Flash kit)
These are what iv just bought from ebay
http://au.youtube.com/watch?v=hsL8Rf0rQBA
really dont care , something that isnt rediculous like child care , thats all i can find
i just need something to give me an income
head down to PEER. theyre always hiring.
im also keen for different work. Been at current job for 4 years, think its time for a change. DOnt wanna go earn less money though, so if anyone knows o a decent job going at over $19/hr let me know :cool:
same here, ive only been at the current job for 2 years, but never having weekends and all that takes its toll fair quick.
I'm starving... anyone keen for lunch at villies today? :thumbsup:
Well, Kell and I took the Brutale out for a ride to the Bay for a late lunch. :)
 Share
    • Much less twat-tastic. CF wheels are too garish for civilised use.
    • From there, as the manual says....assembly is the reverse of disassembly, no tricks worth mentioning Much better (for me)
    • In my case, the standard wheel I had was in good condition but the buttons had more wear, so I swapped them across from the original wheel from the car. The plastic rear cover is held on by 4 tabs, and once the wiring is removed you can get access to 2 screws on each side the hold the buttons in From there I just swapped the wiring over. What was interesting is the standard style wheel is 2.0kg but the carbon fibre one is 50% heavier at 2.9kg. It even has a weight inside the wheel at the top to make up for some sort of imbalance in the design. weird
    • Once the airbag is off, to remove the steering wheel.... Undo the 2 plugs into the clock spring, and the horn connector from it's clip. Hit the 19mm nut with a rattle gun (preferably) or if you don't' have one, you probably want an assistant to hold the wheel in place while you use a breaker bar to undo the nut Then, screw the nut back on 3 turns, and pull the wheel sharply towards you. If that doesn't work hit it medium force with a rubber mallet on either side, or possible behind if you can get there. If that all fails (it shouldn't!) you might need a steering wheel puller
    • So, to next task....the carbon fibre steering wheel was either an expensive factory option or a chinesium special. Either way, I don't like either the flat bottom or thick ring style, so it had to go So...to remove the steering wheel.... First, disconnect battery negative and stomp on the brake pedal for a few seconds. Then, remove the small circular covers on each side of the wheel's rear surround to uncover the airbag clips. You need to push something like a flat bladed screw driver through, to push the steel clip inwards and pull the side of the airbag forward. Once you've done the easy side, same on the centre console side. You can see the tab you are shooting for circled in red Then, disconnect the horn spade connector and for the yellow airbag plug you need to get something small under the black locking tab to pop it out, then the connector releases......airbag is off
